Possible Bent Valve??
Old Nov 4, 2005 | 04:42 PM
96CivicBoostCoupe's Avatar
Default Possible Bent Valve??
I have a 99 Si with an 00 ITR motor in it and its making this sort of like clacking sound and has a shitty idle, but you only really hear the clack at idle, not so bad through the power range.and it dosn't sound like a rod knock. Is there any way I can diagnose a bent valve without removing the head?? Thanks in advance
Old Nov 4, 2005 | 04:49 PM
madcrossover's Avatar
Default Re: Possible Bent Valve?? (96CivicBoostCoupe)
All I can say is to do a compression check and see what numbers you get. If you get a real low number off from the others, then its a bent valve.
Old Nov 4, 2005 | 05:17 PM
my_slow_civic's Avatar
Ever have your valves adjusted?
Old Nov 4, 2005 | 05:19 PM
si0385.'s Avatar
Default Re: Possible Bent Valve?? (my_slow_civic)
i would start with adjusting the valves
Old Nov 4, 2005 | 05:43 PM
Default Re: Possible Bent Valve?? (turbodreamz0385)
yeah I adjusted my valve clearence today .006" for the intake and .008" for the exhaust, still runs like **** and in addition to the clacking sound it has like a gulping air swirling sound so it leads me to believe that one or more is bent and stayin open. I dont know, im going to pull the head in the morining, but anymore input would be well appriciated
hylaxrng
Dec 17, 2013 11:03 PM
Ryanwill86
Jan 14, 2009 06:04 PM
Tegraracer90
Aug 6, 2008 09:33 AM
Th3savinday
Apr 19, 2008 09:47 AM
HX_Guy
Nov 7, 2001 08:39 AM
