gauge wiring
Old Nov 4, 2005 | 02:38 PM
imskatencrzy's Avatar
Default gauge wiring
hey guys. i just bought a voltmeter for my 93 civic ex and im trying to figure out where to wire it. negetive obviously goes to a ground, which is easy enough. but the power needs to go to a source that is "hot" when the key is on "accessory". so im a wiring coward and i dont want to expletive my car up so where and how do i wire it? help a brother out!! thanks.
Old Nov 4, 2005 | 02:54 PM
nub's Avatar
nub
Default Re: gauge wiring (imskatencrzy)
you can hook it up to the blk/yel that is in the ignition switch harness under dash
515blue2kSi's Avatar
Look for a 12 or 14 Gauge Yellow wire coming from the ingnition. That will be your best source for Accessory.
Old Nov 4, 2005 | 02:59 PM
nub's Avatar
nub
Default Re: gauge wiring (515blue2kSi)
the yellow will also work (ignition #2) the black and yellow is your #1 ignition whatever
Old Nov 4, 2005 | 03:15 PM
Default Re: gauge wiring (nub)
ok, thanks, should i use a butt end connector or what?
Old Nov 4, 2005 | 03:30 PM
Use a wire Tap, you dont want to cut that wire if you dont have to.
Old Nov 4, 2005 | 08:21 PM
is my cigarette lighter hot when the ignition is off? because my radar is not running all the time, and i have heard of people splicing their gauges there.
leftychang
Welding / Fabrication
23
May 6, 2008 04:38 AM
king_me
Nov 16, 2006 07:38 AM
tyflip2
Jun 14, 2004 03:08 PM
killa_lude
Nov 19, 2003 01:32 PM
EX-T
Jul 22, 2003 08:50 PM
