cracked head?
Old Nov 4, 2005 | 10:06 AM
89 pos's Avatar
Default cracked head?
i just replaced the haed on my 92 ls. i was flushing out the coolant system and found water in my oil so i took off the valve cover and started the water an it is spraying water out the head at the 3 cyl valve
Old Nov 4, 2005 | 10:40 AM
HONDA RR's Avatar
Default Re: cracked head? (89 pos)
I recommend you to get another head. Its not wise to fix a cracked cylinder head.
Old Nov 4, 2005 | 11:12 AM
LsVtec98's Avatar
coolant in the oil doesn't always mean cracked head. did you replace the head gasket when you replaced the head?
Old Nov 4, 2005 | 01:55 PM
89 pos's Avatar
Default Re: (LsVtec98)
yes , but the cyd is not filling up with water so its not the head gasket it almost like is in a coolant passage next to the intake valve it squrting out
93baggedcivic
Dec 20, 2007 03:41 PM
7rrivera7
Dec 20, 2007 07:46 AM
whoneedzvtec
Mar 16, 2007 07:43 PM
B18c1turboedEK
Jun 10, 2004 07:53 AM
