H22 EG Shifter Box
Old Nov 3, 2005 | 07:38 PM
T
Default H22 EG Shifter Box
Okay I have an H22 EG hatch and there is far too much play on the shifter, I was told too tighten the cables to the shifter box. I just swapped trannies. Where is the shifter box located? If anybody has any suggestions, they would be greatly appreciated. I don't know what to do and I can't drive the car until this is fixed. Please help.
Old Nov 3, 2005 | 07:50 PM
Gillard82's Avatar
Default Re: H22 EG Shifter Box (JDMH22EGstreetsleeper)
need a litttle more info. the shifter once in place should be secure. shifter cables are secured to the shifter box itself by a clip
Old Nov 4, 2005 | 09:23 AM
T
Default Re: H22 EG Shifter Box (Gillard82)
This is really all I got. The shifter itself has too much play and is very wobbly and grinds when goes into gears. I was told to tighten cables to the shifter box. THey said once I tightened the cables it should fix the problem.
Old Nov 4, 2005 | 10:21 AM
raminsco's Avatar
there are bushings in under the actual shift lever that you can only get to from underneath the car. i have had this problem several times with my hatch. it is caused by jiggling the shift lever around like a ridiculous moron. i do it. everyone does it. nothing you can do about but replace the bushings.
Old Nov 4, 2005 | 10:27 AM
IHateJDM's Avatar
Default Re: H22 EG Shifter Box (raminsco)
how was the shifter installed in your car? is it the stock mounting plate, or a shift box like place racing makes? if one of the clips that holds the shift cable in place (2 at the shifter, 2 at the tranny) came loose, then that could cause your problem.
Old Nov 4, 2005 | 10:36 AM
T
Default Re: H22 EG Shifter Box (IHateJDM)
I think it is placeracing cuz I have placeracing engine mounts.
Old Nov 4, 2005 | 10:39 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22EGstreetsleeper &raquo;</TD></TR><TR><TD CLASS="quote">I think it is placeracing </TD></TR></TABLE>
I have that shift box too. all black and bolts to the bottom of the car? if so, those clips can't come out. the box forces them up against the body of the car, you have to drop the shifter box to loosen the clips. Are you sure you didn't lose one on the tranny end?
Old Nov 4, 2005 | 10:45 AM
T
Where could I find it at on the tranny? What if I don't have that one where would the stock one be? I think they're on they just need to be tightened.
Old Nov 4, 2005 | 10:50 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22EGstreetsleeper &raquo;</TD></TR><TR><TD CLASS="quote">Where could I find it at on the tranny? What if I don't have that one where would the stock one be? I think they're on they just need to be tightened.</TD></TR></TABLE>
it can't really be tightened if that's your problem. either its clipped in, or its not. The stock one would be in the cabin of the car at the base of the shifter. on the tranny end, look under your intake and you'll see the 2 levers that the shift cables are connected to. about 4-5 inches from where they connect to the levers, there is a bracket the cables connect to. this is where they are clipped in place.
Old Nov 4, 2005 | 10:55 AM
T
Well they're clipped in. The people who have H22 swaps in the EG chassis how does your shifter feel? Is it tight like stock? Loose? Please help.
Old Nov 4, 2005 | 10:58 AM
IHateJDM's Avatar
it's loose compared to linkage shift cars (B's and D's), but you shouldn't have a problem hitting your gears shifting at a normal speed.
Old Nov 4, 2005 | 11:01 AM
T
thank you.
DeeJHonda95
Transmission & Drivetrain
Feb 13, 2014 04:50 AM
K24CRXTX
Texas -OK -LA (Sales)
15
Jan 7, 2011 07:02 AM
accord2civic2prelude
Apr 14, 2010 11:30 AM
94lt1
Nov 23, 2007 03:25 PM
