starting problems
Old Nov 3, 2005 | 06:05 PM
Mad Hatter's Avatar
Default starting problems
so i got my '92 si back from getting an h22 swap, and its having problems starting. pretty much, the ignition just turns (theres a spark, but it doesnt start). it doesn't do this everytime and it was doing this before the swap, so i think its the fuel pump. the only thing thats really worrying me is that sometimes it will make a scraping noise too, whether it starts or not. would this also be caused by the fuel pump, or is it something else?
Old Nov 3, 2005 | 06:52 PM
Mad Hatter's Avatar
Default Re: starting problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude15 &raquo;</TD></TR><TR><TD CLASS="quote">main relay. Common problem. look it up. other than that, a fuel pump is a possibility. when you turn your ignition you should hear a "suuump....click". when your relay is out it doesn't do this, at least mine doesnt. otherwise, check all the ignition components.</TD></TR></TABLE>
thanks for the response...i did a search and i figured it is probably either the fuel pump or the main relay, but nobody mentioned this sound im getting. the car will crank like its supposed to, but then after like 2 or 3 seconds theres awful scraping noise...i don't know if i'd describe it as a "suuump...click" though....
Old Nov 3, 2005 | 10:05 PM
Mad Hatter's Avatar
bump for some help...
Old Nov 4, 2005 | 04:17 AM
kulrevon's Avatar
Default Re: starting problems (i'm so lude)
is the noise coming from the back or the car (ie fuel pump) or the front?
Old Nov 4, 2005 | 09:31 AM
Mad Hatter's Avatar
Default Re: starting problems (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">is the noise coming from the back or the car (ie fuel pump) or the front?</TD></TR></TABLE>
i don't remember and it didn't have any problems this morning. thanks...i'll listen a lil better next time that happens
crazyimport
Sep 2, 2008 09:22 AM
italstallion
Jul 11, 2006 03:04 PM
s.khang
15
Dec 16, 2003 01:46 PM
2camsaam
Jul 14, 2003 09:09 AM
Aquafina
Jul 8, 2003 07:35 PM
