check engine light question
Old Nov 3, 2005 | 02:38 PM
WERD up's Avatar
Default check engine light question
just swapped in b16, redlined, check engine light's now on. serious problem?
Old Nov 3, 2005 | 02:39 PM
31flavorscivic's Avatar
Default Re: check engine light question (werd_up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">serious problem?</TD></TR></TABLE>
¿Depends on what code it's throwing?
Old Nov 3, 2005 | 02:49 PM
onepoint6i's Avatar
Default Re: check engine light question (31flavorscivic)
w3rd...
what code is it throwing??
Old Nov 3, 2005 | 02:51 PM
WERD up's Avatar
Default Re: check engine light question (onepoint6i)
how would i get that info? yea total newbie
Old Nov 3, 2005 | 02:52 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">how would i get that info? yea total newbie </TD></TR></TABLE>
pull out your ECU
count flashes
tell us
Old Nov 3, 2005 | 02:54 PM
Default Re: check engine light question (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">just swapped in b16, </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">yea total newbie </TD></TR></TABLE>
Do those two even go together? Swapping a b16 isn't exactly easy work...
Old Nov 3, 2005 | 02:56 PM
WERD up's Avatar
do i have to unplug the ecu or just remove the cover and count the flashes? im at work right now so i'd have to wait til i get home first. i have a jdm b16 so the ecu is upside down.
Old Nov 3, 2005 | 02:57 PM
WERD up's Avatar
i meant 'paid' for a swap
Old Nov 3, 2005 | 02:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">i meant 'paid' for a swap</TD></TR></TABLE>
ah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">do i have to unplug the ecu or just remove the cover and count the flashes? im at work right now so i'd have to wait til i get home first. i have a jdm b16 so the ecu is upside down.</TD></TR></TABLE>
While it's plugged in.
Old Nov 3, 2005 | 03:04 PM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">
While it's plugged in. </TD></TR></TABLE>
eggzachery!
coot_er's Avatar
Do those two even go together? Swapping a b16 isn't exactly easy work...</TD></TR></TABLE>
i was a noob when i did mine, before that i only had done a couple of oil changes.
anyhow, just take the cover off so that you can see the glass eye looking thing, it should be flashing. (keep it plugged in) count the flashes the long ones count as ten and the short ones count as one
so long-long-short pause long-long-short ...would be code 21
Old Nov 3, 2005 | 03:06 PM
WERD up's Avatar
well maybe i can check it on my break if the cover's not on too tight *crosses fingers*
Old Nov 3, 2005 | 03:09 PM
WERD up's Avatar
so does long long short indicate . what indicates a problem?
Old Nov 3, 2005 | 03:16 PM
coot_er's Avatar
if there is not blinks then there is not a problem.
thats why you are looking at your ecu, because you know you have a problem.
21 was just an example.
Old Nov 3, 2005 | 03:26 PM
Default Re: check engine light question (coot_er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">i was a noob when i did mine, before that i only had done a couple of oil changes.
I had no prior experience either, but my point was by that point one should be able to check the ecu, which he paid to have his motor done so n/m. The whole reason I did my swap was because my CEL would pop on daily and I was always checking codes, as my old engine was literally falling apart right in front of my eyes for about a month.
Old Nov 3, 2005 | 06:40 PM
WERD up's Avatar
ok so i just got home, checked the ecu and it blinked 6 short times. diagnosis?
Old Nov 3, 2005 | 07:30 PM
water temperature sensor? Someone chime in here I'm not an expert for b16 codes but thats all I could come up with.
Old Nov 3, 2005 | 07:45 PM
WERD up's Avatar
i redlined the car today, then after i let it sit for about an hour while i was in class, i came out to start the car it had a little trouble starting up but still fired up. but after i gave it some gas it felt like it didnt wanna go. i gave it some more gas and kept revving up for about 2 minutes while i was driving and it worked fine from then on. this also happened when i got out of work
Old Nov 4, 2005 | 07:22 AM
WERD up's Avatar
bump
ITRiWISH
11
Aug 27, 2007 05:24 PM
djgalloway73
May 11, 2005 05:08 PM
Alikat
Feb 20, 2005 07:27 AM
wAnA_CiViC
13
May 30, 2004 08:07 PM
afterburners
Feb 2, 2004 05:18 AM
