Stock shifter question
the bearing at the bottom of the shifters are different widths. The civic is narrower, but you could probably make up the width difference with some washers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 »</TD></TR><TR><TD CLASS="quote">they are technically interchangeable, but the 88-00 civic shifter is single bend, and 90-01 integra shifters are dual bend.
my 93 tegs shifter was a single bend. i know that the dc modle tegs have dual bends
</TD></TR></TABLE>my 93 tegs shifter was a single bend. i know that the dc modle tegs have dual bends
I know for a fact that 96-00 (EK) shifters will not fit a 92-95 (EG) shift linkage. So, I'm not sure if it'll work or not.
</TD></TR></TABLE>I know for a fact that 96-00 (EK) shifters will not fit a 92-95 (EG) shift linkage. So, I'm not sure if it'll work or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 »</TD></TR><TR><TD CLASS="quote">i got a EK shifter...wondering if it can fit a 2000 Integra GSR</TD></TR></TABLE>
the base is the civic shifter in small in diameter to fit the integra. unless you wanna use washers or something. if it's like a skunk aftermarket, it should come with a spacer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 »</TD></TR><TR><TD CLASS="quote">the bearing at the bottom of the shifters are different widths. The civic is narrower, but you could probably make up the width difference with some washers.</TD></TR></TABLE>
what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 »</TD></TR><TR><TD CLASS="quote">yah...i know that there is 1 or 2 bends..but in terms of performance...what differances does it make?</TD></TR></TABLE>
It's closer to you so it is easier to shift you don't have to be as far foward.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 »</TD></TR><TR><TD CLASS="quote">Should i try another Short shifter? that actually have a brand on it? or should i just go back to stock shifter?</TD></TR></TABLE>
i like my stock gsr one, the throw is pretty good already, if anything just get energy suspension shifter bushings...make shifting more precise.
Coupe-R
Mar 20, 2007 04:51 PM
