Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
15" rims, can i fit 215/50/15 tires on them?
Old Nov 3, 2005 | 03:38 AM
90teg's Avatar
Default 15" rims, can i fit 215/50/15 tires on them?
I have the rota group n's 15x6.5. i know i can fit 205/50/15 on it, can i fit 215/50/15?
Old Nov 3, 2005 | 04:04 AM
Boilermaker1's Avatar
I can't see why not.
Don't people stuff 205s on stock CRX rims or something?
Old Nov 3, 2005 | 04:11 AM
bender's Avatar
Default Re: 15" rims, can i fit 215/50/15 tires on them? (90teg)
Should be no problem for the rim. Lots of people run 225/50/15 on 15 X 6 in D Stock autocross, so 215 on 6.5 should be much easier. Whether they will rub is a whole different issue.
Old Nov 3, 2005 | 04:13 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: 15" rims, can i fit 215/50/15 tires on them? (bender)
225/50 is really too tall, and kind of makes the gearing wonky. 215/50 would do the same thing, just not quite as bad. If that matters to you, keep it in mind.
Old Nov 3, 2005 | 04:24 AM
Black R's Avatar
25 Year Member
.....what tires did you find in 215/50/15 that are worth a damn?
Old Nov 3, 2005 | 05:06 AM
90teg's Avatar
haven't found a good tire in the size yet. i have s-techs with kyb agx's. i don't want to rub in the rear, that's why i'm asking. it doesn't have to be 215/50/15, i was mostly askin about the 215 size of the tire, it'll give me better traction right?
Old Nov 3, 2005 | 05:07 AM
90teg's Avatar
Default Re: 15" rims, can i fit 215/50/15 tires on them? (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">225/50 is really too tall, and kind of makes the gearing wonky. 215/50 would do the same thing, just not quite as bad. If that matters to you, keep it in mind.</TD></TR></TABLE>
what do you mean gearing wonky?
Old Nov 3, 2005 | 05:17 AM
Suspetise...
A taller tire would give you taller gearing. That may cancel out any benefit from the little bit of extra rubber. Also, the compound of the tire will make a bigger difference than the size. A 205/50 Azenis for example will be much better than a 225/45 all-season.
Old Nov 3, 2005 | 06:47 AM
90teg's Avatar
Oh ok, so i should just stick with 205's then. Well winter is coming up so I was going to get an all-season tire. Azenis is for both wet and dry?
Old Nov 3, 2005 | 06:50 AM
90teg's Avatar
I was told that they were faster then yoko es100's. Which is a better for the price?
Old Nov 3, 2005 | 07:02 AM
Suspetise...
Default Re: (90teg)
What are you doing with them? Neither the Azenis or ES100 is anywhere near an all-season, and both will suck a ton in any kind of snow. For which one would be better for you, that all depends on your purpose.
Old Nov 3, 2005 | 07:04 AM
90teg's Avatar
Well then those are out of the picture. Ok so about this gearing issue you talked about, I have a Y1 tranny. 205 or 215 on DA integra with tein springs?
Old Nov 3, 2005 | 07:05 AM
90teg's Avatar
I'm talking about with B.F. Goodrich T/A KDW, tires.
Modified by 90teg at 4:43 PM 11/3/2005
Old Nov 3, 2005 | 07:16 AM
Suspetise...
Default Re: (90teg)
You're still going to want a 205. And really, even if you looked hard, finding a 215/x-15 tire is near impossible. BFG KDW will also not be so hot in snow. I picked up some Falken Ziex 512s for cheap, and they're a pretty decent all-season. Not horrendous for dry weather either. Try http://www.vulcantire.com
bender's Avatar
I agree. I went thru one set of 225/50/15 V710s for the front, and am now back to 205 all around. The extra width isn't enough to justify the taller gearing, extra weight, and extra cost. Not to mention tearing the hell out of my fender liners...
If Kumho would make 225/45/15 V710, that would be a different story...
Old Nov 3, 2005 | 07:25 AM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bender &raquo;</TD></TR><TR><TD CLASS="quote">If Kumho would make 225/45/15 V710, that would be a different story...</TD></TR></TABLE>
I know some manufacturers have R-comps available in this size, but I'm not sure which ones. Bummer that the V710 isn't one of them.
AiL45
Dec 22, 2006 06:59 AM
808State
Jan 30, 2005 12:48 AM
NickEG
Apr 25, 2004 09:41 AM
Thrillhouse
May 16, 2003 07:09 AM
M-Type
Apr 1, 2003 10:32 AM
