ls block, 95mm crank, 1.54 r/s ratio?
Old Nov 3, 2005 | 03:23 AM
FATBOYeg6's Avatar
Default ls block, 95mm crank, 1.54 r/s ratio?
just like the title says. i have an ls block, and a 95mm crank. i would like to keep the ls r/s ratio of 1.54. how tall of a deck plate will i need, and do any companies make off the shelf rods for this? if not, what rod length would i need with what deckplate size. thanks.
Old Nov 3, 2005 | 07:10 AM
CHEETAH's Avatar
Default Re: ls block, 95mm crank, 1.54 r/s ratio? (ninefivehatch)
dont need deckplate you can use a longer rod and have the piston compression height offset to get back close to 1.5ish r/s ratio
Old Nov 3, 2005 | 10:29 AM
Combustion Contraption's Avatar
What do you think of raised wrist pin height pistons for street motors, cheetah?
Old Nov 3, 2005 | 10:40 AM
CHEETAH's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">What do you think of raised wrist pin height pistons for street motors, cheetah?</TD></TR></TABLE>
there are different versions of "street" like dauly driver or weekend car with few races, etc.
anyway, for my street car which I drive a few times a week plus race on weekends, I use a 92mm crank and offset Endyn pistons and it works great. I wouldn;t recommend too much offset, however cause the rings just take a lil more beating, so for a 95 crank i wouldn't do a full street car daily driver.
Old Nov 3, 2005 | 12:51 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">
anyway, for my street car which I drive a few times a week plus race on weekends, I use a 92mm crank and offset Endyn pistons and it works great. I wouldn;t recommend too much offset, however cause the rings just take a lil more beating, so for a 95 crank i wouldn't do a full street car daily driver.</TD></TR></TABLE>AGREED !!!!!!!!!!!
Old Nov 3, 2005 | 01:12 PM
Rocket's Avatar
Default Re: (HOOKUPS)
1.54 R/S works good. I know of a racer that has a 92mm crank and 1.54 r/s.
Old Nov 3, 2005 | 05:06 PM
FATBOYeg6's Avatar
Default Re: (Rocket)
i was pretty set on 95mm, but maybe i should sell the 95mm and get a 92mm. so 92mm with an offset pin piston could be daily driven?
Old Nov 3, 2005 | 05:08 PM
CHEETAH's Avatar
Default Re: (ninefivehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninefivehatch &raquo;</TD></TR><TR><TD CLASS="quote">i was pretty set on 95mm, but maybe i should sell the 95mm and get a 92mm. so 92mm with an offset pin piston could be daily driven?</TD></TR></TABLE>
yeah i use the 92mm setup in my street car ... there is a thread on the motor build with dyno charts ... I run it with 93 octane on the street and its only 84.5mm bore
greg
Old Nov 5, 2005 | 09:27 AM
FATBOYeg6's Avatar
yeah i use the 92mm setup in my street car ... </TD></TR></TABLE>
i read your setup, sounds good. any tips for a 92mm crank street car?
PhatwhipsJDMkits
Mar 30, 2012 06:27 AM
Gaspari
Sep 14, 2010 01:42 PM
Civic92Turbo
Mar 4, 2007 06:41 PM
nebulight
Nov 9, 2006 07:49 AM
allaboutdaz
Aug 19, 2006 10:56 AM
