Main bearing clearence.
Old Nov 2, 2005 | 11:40 PM
B-B-K's Avatar
Default Main bearing clearence.
I asked this in the All Motor forum since its for an NA application and I mostly hang out in that forum, but Im thinking someone in this forum might be able to help me out.
https://honda-tech.com/zerothread?id=1422366
Thanks for any input.
Matt
Old Nov 3, 2005 | 09:53 AM
2001accord's Avatar
Default Re: Main bearing clearence. (B-B-K)
If you are going for hp in the NA version you need to add clearance to the bearings. A rule of thumb is .001 for every inch in diameter for that journal. For example my H22 had a 1.89 inch diameter rod journal, so the bearings are .0017-.0018. Not sure on your particular crank but does sound a little big. I would also recomend using the honda bearings, b/c alot of people have had issues spinning ACL's. Also don't go by just the plastiguage, use a dial indicator as well they are more accurate.
Old Nov 3, 2005 | 05:20 PM
bosco500's Avatar
Default Re: Main bearing clearence. (2001accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001accord &raquo;</TD></TR><TR><TD CLASS="quote"> I would also recomend using the honda bearings, b/c alot of people have had issues spinning ACL's.</TD></TR></TABLE>
I've used ACL's on all of my race motors... no probs so far. Who is "a lot of people"?
Old Nov 4, 2005 | 10:12 AM
stealthmode62's Avatar
Default Re: Main bearing clearence. (bosco500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bosco500 &raquo;</TD></TR><TR><TD CLASS="quote"> Who is "a lot of people"?</TD></TR></TABLE>
Alot of people means 2 people who made 3 threads each on HT about spinning thier ACL bearings, and now 1,243,454 have just repeated it any chance they get because they don't realize that bearing CLEARANCES owned the original 2 people.
sanjay2
Jun 14, 2010 07:21 AM
I_eat_Rice
Jul 6, 2008 12:58 AM
pumpkyn
Oct 6, 2006 02:26 PM
Baron55
Aug 28, 2006 12:37 PM
PM-Performance
May 28, 2003 10:02 PM
