quaife steering rack
Old Nov 2, 2005 | 09:24 PM
egb18c5's Avatar
Default quaife steering rack
since quaife hasn't made a steering rack for 96-00 civics, i was thinkin it might work for people that are going to use the EG subframe for the k series swap.
i was readin honda tuning and it said hasport has mounts that necessitates the use of an EG subframe (ekk2), then that means that the quaife steerin should work.
i'm a noob at this part, so bare with me, but after lookin at this post https://honda-tech.com/zerothread?id=1317231 it seems like it would work
can anyone verify this for me, thanks
Old Nov 2, 2005 | 09:57 PM
duggy's Avatar
info on this steering rack? what are the benefits?
Old Nov 2, 2005 | 10:04 PM
SOHC4life 96's Avatar
Default Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy &raquo;</TD></TR><TR><TD CLASS="quote">info on this steering rack? what are the benefits?</TD></TR></TABLE>
There is a huge thread about it in the road racing forum. But in a nut shell, it shortens the number of turns from lock to lock. So basically if it takes 4 turns to go from all the way right to all the way left, the quaife steering rack will shorten that to 2-2 1/2 (this is just an example I don't know the exact numbers)
Benefits? It's really only for auto crossers/road racers. You will be able to turn the wheels with a lot less input at the steering wheel.
To the original poster, that is a good idea if it works.
Old Nov 9, 2005 | 08:12 PM
egb18c5's Avatar
Default Re: (SOHC4life 96)
can anyone else verify this??
Old Nov 9, 2005 | 08:19 PM
94civicCx's Avatar
so.... doesnt this make it good for daily driven?
Old Nov 9, 2005 | 08:31 PM
carbonk20's Avatar
Default Re: (egb18c5)
true story, it will change it to just under 3 rotations lock 2 lock instead of 4. It takes much less effort if your not used to a manual rack.
Old Nov 9, 2005 | 08:38 PM
carbonk20's Avatar
Default Re: (carbonk20)
Check out the link in the post above. This guy did a great job of laying the whole thing out.
unix4linux
Suspension & Brakes
Aug 22, 2011 04:12 PM
powersteer
Mar 28, 2006 01:57 PM
ekim952522000
11
Mar 6, 2006 11:10 PM
freakasis
13
Jul 21, 2005 09:52 AM
98integraLS
23
Jul 23, 2004 02:34 PM
