Quicker steering rack??
Old Feb 16, 2006 | 06:21 PM
powersteer's Avatar
Default Quicker steering rack??
Hi guys,
I have a JDM DB8 type r, found my steering rack leaking alittle. Since I'm gonna swap it out, I'm wondering whether there is another Honda using a compatible (to ST7) steering rack which is faster lock to lock than my current one. It will be a nice bonus if the turning radius can be reduced at the same time.
But most desired result is to have a faster steering rack (lock to lock) which offer me the same steering feels.
So guys, any experience in this? Please advise.
Old Feb 16, 2006 | 08:27 PM
Reid's Avatar
Global Moderator
Default Re: Quicker steering rack?? (powersteer)
The JDM ITR race base model had a quicker steering rack. It does not have power steering.
When I get the part number, I will try to order one from Honda. I'm not sure if they're still available though.
Old Feb 19, 2006 | 06:38 PM
powersteer's Avatar
I heard that JDM EG6 SiRII doesnt have PS too.
they might be sharing the same rack?
Does anyone have info on the part number, turns lock to lock, turning radius (steering angle)?
Old Feb 19, 2006 | 06:46 PM
friz's Avatar
Default Re: (powersteer)
My JDM SiR II swap came with a pwr steering pump attached.
Old Feb 20, 2006 | 07:57 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">I heard that JDM EG6 SiRII doesnt have PS too.
they might be sharing the same rack?</TD></TR></TABLE>
The SiRII has power steering. The JDM ITR race base steering rack was not available in any other car except for the race base ITR.
Old Feb 20, 2006 | 11:42 PM
powersteer's Avatar
Does anyone have the part number for the steering rack that comes with the race based DC2R?
Old Feb 21, 2006 | 12:40 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powersteer &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have the part number for the steering rack that comes with the race based DC2R?</TD></TR></TABLE>
When I get the part number I'll let you know. I'll also let you know if they're still available.
I sure hope they're available.
Old Mar 5, 2006 | 12:03 PM
Gunns's Avatar
Any luck with getting the the part number for this rack?
Old Mar 6, 2006 | 02:27 AM
Reid's Avatar
Global Moderator
Default Re: (Gunns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gunns &raquo;</TD></TR><TR><TD CLASS="quote">Any luck with getting the the part number for this rack?</TD></TR></TABLE>
Not yet, I'll update this thread as soon as I find the part number.
Also, I'll let you know if it is still available from Honda.
Old Mar 28, 2006 | 06:48 AM
SASi's Avatar
Default Re: (Reid)
any update
Old Mar 28, 2006 | 10:08 AM
NJcoupe's Avatar
http://locashracing.com/store/...id=72
Quaife Steering Rack Gear kit.
Quick Ratio Steering Gear Kit for 92-95 Civic (non-power steering) and 94-01 Integra (Integra owners will need to obtain a complete 92-95 Civic manual steering rack, as this kit does not work on the stock Integra power rack!). The quick ratio rack and pinion gear set is perhaps the most underrated performance part around. The Quaife rack and pinion gears simply replace the existing pieces inside your stock steering rack housing. More rapid steering response is felt with an average of 25 percent reduction in ratio, resulting in approximately 3.1 turns lock-to-lock. (Stock 92-95 Civic is approximately 4.1 turns lock to lock) This translates into much quicker steering and turn in at the cost of a slight increase in effort. A must for autocross, drifting, and track work. Designed to fit manual steering racks only. Not for power steering.
$240.00
Old Mar 28, 2006 | 10:19 AM
SASi's Avatar
Default Re: (idriveacoupe.)
So if I put in the Quaife steering rack will that make it easier to steer in parking lots and at low speeds. Or does it only redues the turns lock to lock. I currently have PS and I want to get rid of it. I am going to be going with an H22 swap...and I dont want to use PS.
Thanks
Old Mar 28, 2006 | 10:50 AM
NJcoupe's Avatar
Default Re: (SASi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SASi &raquo;</TD></TR><TR><TD CLASS="quote">So if I put in the Quaife steering rack will that make it easier to steer in parking lots and at low speeds. Or does it only redues the turns lock to lock. I currently have PS and I want to get rid of it. I am going to be going with an H22 swap...and I dont want to use PS.
Thanks</TD></TR></TABLE>
It will not help that much, as it is nothing like a powersteering rack where the fluid is constantly being pushed/pulled throughout the rack. The reason is so hard to turn at mph's is when you turn, you're moving the fluid in the rack yourself, hence why it's called powersteering, being powered by the pump.
So intern, It might make it a little easier, but nothing of the sort of something with powersteering.
Old Mar 28, 2006 | 11:32 AM
Lsos's Avatar
Default Re: (SASi)
Having a quicker steering rack will make it harder to steer.
Old Mar 28, 2006 | 11:51 AM
SASi's Avatar
Default Re: (Reid)
Well, the race based DC2R is a non power rack....wouldnt that do both for me. Make it easier to turn...and decrease lock to lock?
Old Mar 28, 2006 | 12:39 PM
ITR#132's Avatar
Default Re: (SASi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SASi &raquo;</TD></TR><TR><TD CLASS="quote">Well, the race based DC2R is a non power rack....wouldnt that do both for me. Make it easier to turn...and decrease lock to lock?</TD></TR></TABLE>
Are you RHD?
Old Mar 28, 2006 | 01:57 PM
SASi's Avatar
Default Re: (ITR#132)
No sir I am not....so I guess that I am screwed out of that option then. What do you guys recommend? Should I buy a CX steering system, and then get the Quaife to go with it?
fasterthanueg
Northwest (Sales)
Nov 30, 2012 11:28 PM
Mohsin
Oct 7, 2008 01:56 PM
aown61
Apr 11, 2006 06:16 AM
rotten
Oct 17, 2005 05:16 PM
fsp31
18
Apr 29, 2003 05:10 PM
