info on d15b
i wanted to know some stuff about the jdm d15b vtec engine like
could i mate it up to a Si tranny?
if i where to buy parts would i have to import them from jap-land or could i like get parts for a 4g dx and it would fit on it sence there both d15's? are there alot of aftermarket parts or not?
could i use some of the parts from my dx or what?
would it be an easy install?
any info would be nice
i jsut swapped it in my 91 crx, it pulls harder than my pos d16a6. you need to get an obd1 conversion harness, and new 02 sensor and an obd1 dizzy... it ended up costin me a little less than 1000 dollas for the new motor ecu and the stuff i mentioned
however, i drove it for a week and now im getting a CEL 43... hmmm
yep. I have a D15B in the rex now, Si trans. used a P28 ecu, sent the harness to rywire (so i didnt have to rig it!!) I love it, powerful little single cam.
http://hondamarketplace.com/zerothread?id=1414663
oh yea, its for sale!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">could i mate it up to a Si tranny?</TD></TR></TABLE>
Yes, it bolts right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">if i where to buy parts would i have to import them from jap-land or could i like get parts for a 4g dx and it would fit on it sence there both d15's? are there alot of aftermarket parts or not? </TD></TR></TABLE>
No. The head from the jdm d15b vtec is the exact same as the d16z6 head, except the cam in the d15 is more aggressive than the z6 cam. So if you need any replacement parts for the head, like plug wires, buy them as if you were buying them for a z6. However, if you have a block problem, like you need a new crankshaft or something, the block of the d15b is the identical to that of the 92-95 vx civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">could i use some of the parts from my dx or what?</TD></TR></TABLE>
Depends which parts you are talking about. You can use the alternator and flywheel come to mind instantly. Ask about what parts you are refering to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">would it be an easy install?</TD></TR></TABLE>
Pretty straight drop in. You can use the dx motor mounts, keep the dx axles even if you switch over to the si transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">any info would be nice</TD></TR></TABLE>
All the info you ever want to find this swap is a button away... the search button.
Let me give you a run down. You will need to convert from DPFI (dual point fuel injection) to MPFI (multi point). Then you will need to convert to obd-1 using a rywire.com harness. Then pray you dont have any codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bamm_bamm89 »</TD></TR><TR><TD CLASS="quote">im kind of a n00b at the numbers and letters could u help me out like what is a obd1 p28 and stuff like that i know engines but im still learning about other stuff</TD></TR></TABLE>
p28 is an enginer computer (ECU). It is the stock ecu for the d16z6. They say to use the p28 ecu because the head of the z6 and d15b vtec are the exact same, same obd, etc. So use the p28. The ecu number should look something like: xxxxx P28 xxxx
here is a site for you that is about the engine http://asia.vtec.net/article/d15b/
ensracer
Jun 28, 2005 05:37 PM
pane93civhb
Feb 15, 2005 12:35 PM
RobbieG35
11
Aug 9, 2004 08:51 AM
