boosting d15b?
Old Nov 2, 2005 | 12:25 PM
thugciti01's Avatar
Default boosting d15b?
i'm new at this and i'm planning on boosting my d15b, is there any thing i should replace or upgrade to the internals or will it be ok stock. thanks for any replies.
Old Nov 2, 2005 | 12:27 PM
.Radical_Edward.'s Avatar
Bounty - € 8,000,000
Default Re: boosting d15b? (thugciti01)
ARP Headstuds should do you fine.
Old Nov 2, 2005 | 12:42 PM
Fenrir51's Avatar
The ARP headstuds reduce the chance of head lift which is common using OEM bolts/studs whatever they are.
Old Nov 2, 2005 | 12:46 PM
eg2wes's Avatar
it really depends on how much boost you are planning to run, as said arp head studs are a must to prevent head lift, also a cometic head gasket will help to, you should be safe at 8-10lbs of boost if you get it tuned well.
Old Nov 2, 2005 | 01:03 PM
JDMHatch95si's Avatar
Default Re: (eg2wes)
As stupid as it sounds i saw a D15B run 18 psi and a 35 shot on stock internals , and didnt blow up . Not sure how the hell that works , but im sure with a real nice tune you will be fine at anything below say like 10 psi . Also just be sure to get some good gauges to watch over everything , id go with obviously boost . But also a good air/fuel to make sure you dont lean out , and an oil pressure to make sure everything is on par .
Old Nov 2, 2005 | 01:07 PM
si0385.'s Avatar
ive heard d15b's are prety good under boost, you should be fine up to 10 psi anyways just make sure u got the fuel to supply it and get it tuned!!
ej1252
Nov 12, 2007 03:43 PM
hangac1093
Dec 12, 2006 02:38 PM
ModlesSI
Feb 2, 2004 02:58 AM
VanHonda
Dec 25, 2003 09:33 AM
Ri5e
Sep 9, 2002 01:13 PM
