help. Engine problem.. fuel injector? valve stem seal? bad valve?
my car sputters like its running on 3 valves. I left the car on, went to the engine and started checking the valves starting with #4 to see which one it was. Valve #3 is the problem. I can pull the wire out and the sputtering will stay the same. So I was thinking it was the spark plug so I bought new spark plugs and replaced it, but no difference was made. The only difference is if I take out the spark plug and put it back in and turn the car on, it will run for a few seconds and then start going bad. I switched around the wires to test if it was the wires and it didnt make a difference. I replaced all the spark plugs a month ago and found oil in #3 and 4 all over the spark plugs. But once i replaced the spark plugs everything was fine. Now its doing the sputtering and replacing the spark plugs makes no difference. Does anyone know what this could be?
joe.wong321
20
Mar 5, 2008 07:21 PM
