Spark plug problem.
Old Feb 15, 2007 | 06:16 PM
88crxdxfastwhip's Avatar
Default Spark plug problem.
Sup guys. Today I was changing my spark plugs and I found a lot of oil in the 4th cylinder. Is this normal? Or did something mess up? The car still runs great.
Old Feb 15, 2007 | 06:21 PM
ilovemydc5's Avatar
Default Re: Spark plug problem. (88crxdxfastwhip)
I would check your valve cover seals, seems like it would be a bad seal. most of the time that will cause that to happen.
Old Feb 15, 2007 | 06:22 PM
Default Re: Spark plug problem. (96Accordh22)
Will this mess anything up?
Old Feb 15, 2007 | 06:35 PM
loup05's Avatar
it will eventually mess up ur spark plug. try changing the 4 seals under the valve cver. if that dosnt solve it u will have to go to the dealership and ask for the 'rocker seals" i had the same problem and it turned out to be the rocker seals
if you do the rocker seals u will have to then do a valve adjustment because u have to losen all of the valves because the seals are under the asembly
Old Feb 16, 2007 | 05:56 AM
Honda-Master's Avatar
http://www.hondaaccordforum.co...m.htm
mafia
Mar 26, 2010 10:13 PM
t0kyoStatus
Nov 26, 2008 07:05 PM
usdmEHboy
Jul 23, 2007 09:08 AM
evospeeder
Honda S2000
Jan 25, 2007 02:31 PM
krymson
Jul 20, 2004 04:06 PM
