RMF header, what about exhaust
Old Nov 2, 2005 | 09:41 AM
SilverPanda's Avatar
Default RMF header, what about exhaust
im wondering, if i get an RMF header, what do i need to complete the exhaust, do i need a high flow cat? and what size 2.25" or 2.5" and then what size for the exhaust piping?
Old Nov 2, 2005 | 09:44 AM
98vtec's Avatar
moderator emeritus
Default Re: RMF header, what about exhaust (vtech22)
you will need a 2.5" flex pipe. U dont necessarily need a high flow cat, but i replaced mine with a 2.5" cat while i was doing the header
Old Nov 2, 2005 | 09:46 AM
mgags7's Avatar
as a general rule, you want your exhaust to be as big as if not bigger than your collector....
Old Nov 2, 2005 | 09:48 AM
K-Spec's Avatar
Default Re: (mgags7)
why is that?
Old Nov 2, 2005 | 09:52 AM
98vtec's Avatar
moderator emeritus
Default Re: (khalal538)
cuz if you have exhaust piping that is smaller than the collector its like blowing through a regular drinking straw. If you have the same size exhaust or bigger, its like blowing through a "big gulp" straw (hahaha)
Old Nov 2, 2005 | 09:53 AM
mgags7's Avatar
think about it dude....you have air coming thru the collector....no do you want it to flow out unresricted, or bottleneck it....
if you put a smaller exhaust on you will bottleneck it...
if you couldnt have figured that out for yourself i worry for you...
Old Nov 2, 2005 | 09:55 AM
98vtec's Avatar
moderator emeritus
this is why megaphone collectors are so much greater. at the 4-1 merge, the collector is relatively small and gradually gets bigger, same sort of concept goes with the rest of the exhaust
Old Nov 2, 2005 | 10:21 AM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
if you couldnt have figured that out for yourself i worry for you...</TD></TR></TABLE>
lol, i was wondering if you meant the collector from the header or the collector on the exhaust
Old Nov 2, 2005 | 10:23 AM
haah yeah i know that but ok say i get an RMF header, do you know what the size of the piping is at the end of it? like 2.5"?
Old Nov 2, 2005 | 10:24 AM
mgags7's Avatar
yes 2.5
Old Nov 2, 2005 | 10:26 AM
ok so its 2.5", then i need a test pipe that is 2.5" and say a greddy evo 2 will bolt up to that? im just really confused on this.
Old Nov 2, 2005 | 10:42 AM
mgags7's Avatar
as long as your pipes are equal to or bigger than 2.5" you are fine....i dont see whats so confusing about it....
Old Nov 2, 2005 | 10:52 AM
K-Spec's Avatar
i read somewhere if it's too big and you're not producing enough power to utilize the diameter of the 2.5," it is at a disadvantage? is this true?
Old Nov 3, 2005 | 05:41 AM
andre809_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">i read somewhere if it's too big and you're not producing enough power to utilize the diameter of the 2.5," it is at a disadvantage? is this true?</TD></TR></TABLE>
yeh thats true... but actually you loose lower end torque but gain the top... so its not good if ur runnin in low rpms all the time....(daily driver) I noticed the loss in mine...
Old Nov 3, 2005 | 07:01 AM
Eddiebx's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">cuz if you have exhaust piping that is smaller than the collector its like blowing through a regular drinking straw. If you have the same size exhaust or bigger, its like blowing through a "big gulp" straw (hahaha)</TD></TR></TABLE>
the regular straw and the big gulp straws are the same diameter up here at 7-11, big gulp straws are just longer.
i think u should compare it to a slurpee straw those are fatter
civicboy420
Apr 26, 2015 02:01 AM
TougeCoupe
Apr 29, 2005 07:04 AM
RacerXintegra2k
Jan 20, 2003 08:29 AM
Hukd Up
Jan 9, 2003 11:59 AM
