Southeast MI: big air compressor for sale!
If you work on your own car, a compressor and air tools are mandatory! But good products are a luxury that makes life much easier for the do-it-yourselfer. For body work and suspension stuff you often need lots of volume & pressure that little compressors can't deliver! Here's your chance to upgrade your garage with shop-quality product!
Ingersol-Rand 60-gallon upright tank
belt-driven single-stage 3.5hp motor, 230V
125psi
includes moisture trap canisters
Asking only $150 picked up (cannot ship this!)
Why so cheap for a $600-$800 compressor? Well it is used, and the switch needs to be replaced. Switches go for around $30 (you might slightly increase max pressure with the right switch.) I'm not sure if the electric motor burned out with the switch, so I'm assuming it's no good and making my price low. I've seen motors for around $75. So for around $250 total you have a compressor that will do anything you want it to, and would cost you more than 2X that new.
125psi
ratwellnc
10
May 14, 2008 01:22 PM
97civic123
May 27, 2006 05:50 PM
