What would be better for me
Old Nov 1, 2005 | 10:46 PM
Cerberus2k7's Avatar
Default What would be better for me
Now, this is an intake question. My cars motor is a bit old and could use some air treatment even if it's not that great. So I was wondering if a CAI would be best, or a SRI? Also, I live in the mountains so I also change elevation constantly, go through funky weather, and climb some steep *** hills. So would a CAI help due to the elevation change? But what about water? I've heard about the bypass valves by AEM but i've also seen some e-bay ones. Would those work just as well? I don't plan on driving through many 8"+ deep puddles anytime soon, but I am going to see some rain and snow.
Old Nov 2, 2005 | 04:11 AM
notoriousB's Avatar
Default Re: What would be better for me (Cerberus2k7)
unless you drive through a lake, you don't need a bypass valve.
I would get the CAI as the colder air the better for power production. don't expect a whole lot from an intake, 2-3 hp maybe and a more throaty sound.
Old Nov 2, 2005 | 05:30 AM
HandoEX's Avatar
I drive through puddles with my cai all the time and have never had a problem cai sounds better too
Old Nov 2, 2005 | 08:41 AM
Well, if I go CAI, I could also just make a bypass valve to be on the save side. Shouldnt be too hard. Does anyone have a shot of their CIA installed behind the wheel? Also, a short ram might be better I think because I will also encounter a lot of mud!
Old Nov 2, 2005 | 09:15 AM
HondaAccordTdR's Avatar
Default Re: (Cerberus2k7)
Its not like the CAI is just sitting out in the open, if you are really concerned just but a bypass valve on anyway
Old Nov 2, 2005 | 09:22 AM
I have never really seen one "installed" where the filter is. I've only seen in the engine bay and they say it just sits "6-7 inches" off of the ground so I figured it was out in the open. :$
Old Nov 2, 2005 | 09:40 AM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaAccordTdR &raquo;</TD></TR><TR><TD CLASS="quote">Its not like the CAI is just sitting out in the open, if you are really concerned just but a bypass valve on anyway</TD></TR></TABLE>
You haven't seen what I've seen then. Wheel well liners removed + CIA
Old Nov 2, 2005 | 09:47 AM
have any pics?
Old Nov 2, 2005 | 09:48 AM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cerberus2k7 &raquo;</TD></TR><TR><TD CLASS="quote">have any pics?</TD></TR></TABLE>
of???
Old Nov 2, 2005 | 09:57 AM
"Wheel well liners removed + CIA"
^^That. And I think i'm going to go CIA with a bypass valve and K&N filter. Just wanna see everything that I have to do before and map it out. I've seen in some where you have to take off the bumper, others you don't have to. What is it with 90-93 Accords? O_o
Old Nov 2, 2005 | 01:38 PM
213374U's Avatar
0x5359-0055
Community Builder
Don't have any pics but just a tip..... you DONT want to do this
Old Nov 7, 2005 | 10:13 AM
Well, I got the intake in and started installing it but one problem, it's not wanting to go under enough to clear the damn body! The first part is hooked up and fine, but the second part that looke like a "J" won't go down far enough! The part that's curved is what i'm putting under to attach to the filter and i'm pretty sure that's right? O_o Any ideas?
Old Nov 7, 2005 | 11:18 AM
Do you have to take off the bumper to get this damn thing to fit?
Old Nov 7, 2005 | 12:44 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cerberus2k7 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have to take off the bumper to get this damn thing to fit?</TD></TR></TABLE>
LMAO There is an intake resonator (black box) beneath that hole. You'll have to pull the bumper, remove like 3 screws from the box, and then the CAI will go on just fine
Old Nov 7, 2005 | 12:55 PM
I already took that out. One of those screws was busted, so I took out the other one and it came out. But the CAI seems to be hitting the bumper. BUT! Im using it as just a short ram right now and the temps are already cooler than normal, sounds nice, and i'm noticing more power on the hills. So I think the normal air filter was fucked and letting almost no air in! Anyways, it's raining right now so I may or may not pull the bumper to get it to fit today. How many screws will be holding the bumper on?
Old Nov 7, 2005 | 01:42 PM
fw190bvi's Avatar
Default Re: (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">LMAO There is an intake resonator (black box) beneath that hole. You'll have to pull the bumper, remove like 3 screws from the box, and then the CAI will go on just fine </TD></TR></TABLE>
dont have to pull the bumper, just work from the inner wheel well. raise the car up so the front suspension sags...theres plenty of room to remove the resontator from the wheel well...
running a CAI w/o a fender liner isnt any worse. you fender liner is vented quiet well, and if you have water that high, the intake will still suck up the SAME amount of water, fender liner or not. of course, the filter will get MUCH dirter ALOT sooner.
Old Nov 7, 2005 | 03:04 PM
Ptown17's Avatar
just get a short ram intake from ebay and put a K&N filter and that will do fine, you don't have to worry about water cause its not long like the normal ones, that is why its called short ram intake
Old Nov 7, 2005 | 03:36 PM
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
agree'd. You dont need to take off the bumper, just pull down the liner and the resonator will slip out.
Old Nov 7, 2005 | 04:03 PM
619_eg's Avatar
nowind
Jan 7, 2007 09:08 PM
06CivicNH
Honda Civic (2006 - 2015)
Aug 12, 2006 11:53 PM
raver69
May 22, 2003 12:16 PM
RedLudeSH
Mar 20, 2002 11:34 AM
1.6el
Feb 3, 2002 08:12 AM
