Automatic GS-R?
Old Nov 1, 2005 | 08:46 PM
Acura_99's Avatar
Default Automatic GS-R?
A couple weeks ago I drove thru some water with my CAI and Hydro-Locked the engine. Good news is, my insurance is paying for a new/used engine. I have a 99 teg GS Automatic. Is is possible to replace the stock B18B with a B18C (GS-R) motor with the automatic transmission? If so what will my mechanic need to do this? Of course this is all assuming that I am able to do this (insurance approves it or mechanic fudges a lil bit). Any help would be greatly appreciated.
J
Old Nov 1, 2005 | 08:49 PM
MSP's Avatar
MSP
Default Re: Automatic GS-R? (Acura_99)
Its possible to have an auto-gsr, they have them in japan. I'm not sure if you need to swap to a diff. tranny tho I think all auto tranny's are the same on Bseries motors
Old Nov 1, 2005 | 09:34 PM
brad.'s Avatar
What a great time to do an auto-manual swap!
However, if you just plan on staying auto, I would do so with a b18b
Old Nov 1, 2005 | 09:39 PM
Acura_99's Avatar
Default Re: Automatic GS-R? ([626]96.GSR)
yeah, it would be nice to swap trannys but for now i just wanna swap the motor since my insurance is gonna cover it.
Why would you stick with the b18b?
Old Nov 1, 2005 | 09:46 PM
JDM-EJ1's Avatar
Any B series tranny is compatible with any B series motor. So, yes.. It would work.
Old Nov 1, 2005 | 09:54 PM
brad.'s Avatar
Since an AUTO b18c1 would be
And you dont just change the tranny and "voila!"
Needs the linkage, ecu, etc.
Old Nov 1, 2005 | 10:14 PM
mjc1055's Avatar
You'll need a JDM automatic GSR ECU to run the motor once it's in.. The LS ecu would run the car but not very well, and you wouldn't have vtec. I don't know if there were other automatic vtec cars, perhaps some JDM b16s came with auto trannies, in which case you could use an ECU from one of those, as well.
Old Nov 1, 2005 | 11:53 PM
brad.'s Avatar
Default Re: Automatic GS-R? (mjc1055)
there were auto b16as, so the ECUs can be found
Old Nov 2, 2005 | 12:32 AM
mjc1055's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [626 &raquo;</TD></TR><TR><TD CLASS="quote">96.GSR]there were auto b16as, so the ECUs can be found</TD></TR></TABLE>
Well there ya go then.
Old Nov 2, 2005 | 03:59 AM
MenaceL.A.671's Avatar
if they gonna pay for a new/used motor... just get the 5spd tranny with the motor!
Old Nov 2, 2005 | 08:30 AM
TheGSRGuy's Avatar
Default Re: Automatic GS-R? (m2slsvtec)
You might contact some JDM-importers and see if they can get you an SiR-G auto tranny & the matching ECU. It was available in Japan, but not many people opted for it.
Old Nov 2, 2005 | 08:31 AM
HONDA RR's Avatar
If anything convert your car to a 5spd if your going to run a gsr tranny.
Old Nov 2, 2005 | 09:01 AM
not so JDM Dan's Avatar
Default Re: Automatic GS-R? (HONDA RR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDA RR &raquo;</TD></TR><TR><TD CLASS="quote">If anything convert your car to a 5spd if your going to run a gsr tranny.</TD></TR></TABLE>
Old Nov 2, 2005 | 09:25 AM
SilverDc2's Avatar
Default Re: Automatic GS-R? (JDMDan)
just do a auto to manual conversion, its not that much more, at the end you'll be glad you did it, itr tranny
Old Nov 2, 2005 | 02:09 PM
Liquid Ice NF's Avatar
theres a seller on ebay called "the engine depot" or something.. they carry jdm auto GSR ECUs. for around $100
Old Nov 2, 2005 | 03:24 PM
worditsmenick's Avatar
Default Re: Automatic GS-R? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Any B series tranny is compatible with any B series motor. So, yes.. It would work.</TD></TR></TABLE>
this is kinda true. it will bolt up, but will not run without the auto gsr ecu. a itr motor will bolt up to a auto tranny, but there is NO ecu for it and will not run at all.
skip the jdm auto gsr. get yourself a b20 and then save for turbo while keeping it auto if you like.
good luck and thats awesome that you ins is paying the bill.
Old Nov 7, 2005 | 10:12 AM
acuramike's Avatar
YOU NEED A JDM ECU THAT COMES OUT OF A AUTO GSR FROM JAPAN
Old Nov 7, 2005 | 11:24 AM
Sack Master's Avatar
Default Re: Automatic GS-R? (acuramike)
OBD2, it will probably not pass emissions. Definitely won't with a JDM ecu(you could just swap it though for smog). You may want to check your local laws to see if doing the swap is even legal.
Old Nov 7, 2005 | 02:36 PM
BrooX's Avatar
You will want a GSR engine to be manual. Trust me . Other than that, the LS's are the autos.
Spins
Aug 14, 2004 03:30 PM
ludicrous
Aug 3, 2004 07:50 PM
civic_on_13s
Jul 1, 2003 07:31 PM
BigBank420
Jan 24, 2002 08:13 AM
BigBank420
Jan 24, 2002 07:55 AM
