Motor problem! i need help asap!!!!!!!!!!!!
well i just put a jdm gsr motor in my car, it starts up fine and all that good stuff. The problem i am having is that when i took it out for a spin and press on the gas it accelerates but to a certian ponit, like 10 mph and boggs down and wont go any faster and when i try to shift it is like the shifter is stuck and wont come out. this happens in all the gears. i am stuck and dont know what to check or do. soo can any one help me ?
Wiring Correct?
Check engine light?
linkage bent?
did you use oem honda manual trans fluid, if so did you put in 2 1/2 quarts?
i can help the best i can with out seeing the car?
Check engine light?
linkage bent?
as far as the bogging and acceleration problems, i had my map and iac plugs backwards. as soon as i lenthened one of the plugs, and swapped them it fired up and ran perfect. hope that helps.
i was wrong it is not fixed i am still having the problem. when i changed the spark plugs it ran fine around a couple of blocks but when i started it again like after 2 hours to take it around again it started to bog again. so i am still in need of the help any one please
Modified by Eg6_rAcEr at 11:50 PM 11/2/2005
you say you changed the plugs?
what did they look like?
all 4 brown/ black/silver??
running rich? lean? nothing at all?
i changed the plugs and the bottem of the plugs were black and i am not sure if it is runnign rich, or lean, i think it is just stock
actually my house phone has no long distance do i have an aim screen name i can reach u at. i can actually take a picture of the pulgs if that will help
Eg6_rAcEr
15
Nov 4, 2005 01:30 PM
vtecgod
73
Jul 21, 2005 06:29 AM
