Problem need help....
Ok so here is the problem and yes i searched but i don't see any that fit whats wrong with my car. Ok my alternator belt squeals on and off all the time when its wet and sometimes when its not so i was gonna buy that belt its 13 bucs and change it. Well tonight my idle has been weird like every-time i turn on my light my car will make a weird little sound and my idle will be weird like my car even shut off tonight?
When my light are off tho it don't make that noise ...? do you think i need a new alternator? I think im gonna have it checked tomarrow and see whats up just want your guys opinions thanks... Dan
ya your car is not getting the needed voltage. you car should not die when you turn on the lights. It could either be your battery or alternator. If your alternator is bad then your car will run off your battery until it dies. I would suggest trying to change your battery first. If your alternator goes bad you will know. Trust me
Ya but could the batter be whats makin my car idle weird and the squeling is coming from their two could it be alternator in general or i need a new belt on the alternator and new battery.?
first make sure the belt is tight. Second make sure the connection to the battery is good, not rusted out etc. Next get the alternator tested for free as CSK or something. Start from there
Ok got the alternator tested its good when i turn on my lights its makiung a noise he said it could be a bearing in the alternator. I bought a new belt and im gonna see if this helps if not im gonna need a new alternator bearing prob just put a new alternator in..
One day when I was driving my positive cable came off the battery and when I turned the headlights on the dash, cd player, and everything would shut off and the car would almost die. That's why I am voting it may be a bad battery connection?
yea but its makin a noise man and its messing with my idle when i turn on my lights it makes a noise and idles weird. My belt squiels often ill check my battery connection but i think its my belt or alternator bearing...
crxtreme27
11
Aug 28, 2002 11:29 AM
