Boost HX or Mini Me
Old Nov 1, 2005 | 04:08 PM
skrewdriver88's Avatar
Default Boost HX or Mini Me
Well guys im not sure what would be best to turbo a stock 97 HX(VTEC-E) or boost a mini me. Im not really sure which one has better compression. Thanks
Old Nov 1, 2005 | 04:36 PM
sockvtec's Avatar
Default Re: Boost HX or Mini Me (skrewdriver88)
vtec-e = pointless if your looking for power
i will say do the mini me and turbo it try this https://honda-tech.com/zerothread?id=735196
and stock compression in your d16y5 is: 9.4:1
Old Nov 3, 2005 | 06:30 PM
Default Re: Boost HX or Mini Me (sockvtec)
well i have read and talked to some people and i am going to boost my vtec-e.
Old Nov 3, 2005 | 07:40 PM
sockvtec's Avatar
go for it
post up dome dyno numbers when you get everything done
Old Nov 3, 2005 | 09:09 PM
Turbo_y8's Avatar
yea your gunna be dissapointed id do the head swap and boost youll be a hundred percent happier and youll have a little more options with parts over the y5 head
Old Nov 3, 2005 | 10:34 PM
Doom325's Avatar
I would really like the see a turbo'ed HX, that would very very unique since no one ever does it. I've only seen it done once. The only thing i would suggest to turboing the HX would be to put in an EX tranny. Shorter gears all the way !
Old Nov 3, 2005 | 10:41 PM
sockvtec's Avatar
Default Re: Boost HX or Mini Me (tuck'd98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuck’d98 &raquo;</TD></TR><TR><TD CLASS="quote">yea your gunna be dissapointed id do the head swap and boost youll be a hundred percent happier and youll have a little more options with parts over the y5 head</TD></TR></TABLE>
no let him boost the hx haha
i wanna see 110 whp on 10psi lol
Old Nov 3, 2005 | 11:50 PM
compwc18's Avatar
in my opinion you should get a z6 and turbo it, 8-10 psi, and you will easily get around 200hp with a good tune... its been done... and the compression of a z6 is i believe 9.0/1 please correct me if Im wrong, but I know people who've put ARP headstuds and turbod it and pulled mid 12-high 12 quarter mile times, which isnt bad for a stock z6 turbo'd hehe with a good driver, and a clutch of course.... good luck I would also like to see some dyno numbers
Old Nov 4, 2005 | 06:35 AM
Turbo_y8's Avatar
Default Re: Boost HX or Mini Me (Doom325)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doom325 &raquo;</TD></TR><TR><TD CLASS="quote">I would really like the see a turbo'ed HX, that would very very unique since no one ever does it. I've only seen it done once. The only thing i would suggest to turboing the HX would be to put in an EX tranny. Shorter gears all the way !</TD></TR></TABLE>
yea no one does it cause its pointless, but i do agree with the tranny, before you even boost it get a ex tranny
Old Nov 4, 2005 | 07:20 AM
Hondaciv95VX's Avatar
Mini me it, then boost. Waste of time otherwise, seriously if you boost the stocker, you're a turd.
Old Jan 1, 2006 | 12:02 AM
scoobiez_wrx's Avatar
Default Re: Boost HX or Mini Me (Hondaciv95VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaciv95VX &raquo;</TD></TR><TR><TD CLASS="quote">Mini me it, then boost. Waste of time otherwise, seriously if you boost the stocker, you're a turd.</TD></TR></TABLE>
Geez...this alone has convinced me to do the mini me...
Old Jan 1, 2006 | 12:07 AM
EK k kay's Avatar
Default Re: Boost HX or Mini Me (scoobiez_wrx)
Lots of people boost y7's which are weaker that your y5 and get ~200whp almost just as easily as z6 and y8's do. Going from a y5 to a y8 or z6 head is not worth it in my opinion. The money can be better spent on the turbo parts and tuning
Old Jan 1, 2006 | 12:19 AM
wushubrian's Avatar
Default Re: Boost HX or Mini Me (EK k kay)
Buy an ls motor for 600 bucks and do a home made turbo setup on that for under 400 bucks... u spend under a g and u'll be way happier then with any sohc. You can get most parts for your own turbo kit from a junkyard... All you really have to buy offline is the manifold. I've done a sohc turbo its disappointing.
Old Jan 1, 2006 | 01:34 AM
DasaEJ1's Avatar
Default Re: Boost HX or Mini Me (wushubrian)
get the jdm single cam d15b and turbo it...it'll run a lot better and chipped your ecu to mugen and your'll be good...trust me...the jdm single cam long block is only $350-75 you should use a SI tranny or EX same thing but shorter gear is good for runs...It's a garentee win
Old Jan 1, 2006 | 01:53 AM
9295EJ-t's Avatar
y5=not worth boosting...
get a z6head.. a stock d16z6 has ~9.14:1cr
the d15b wont last as long as the z6.. same rods as a z6, but higher cr..
Old Jan 1, 2006 | 09:16 AM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">no let him boost the hx haha
i wanna see 110 whp on 10psi lol</TD></TR></TABLE>
Stock HX makes 115 hp, so I don't think the vtec-e matters much, prolly make pretty decent power and he wouldn't see vtec-e much if he was driving it hard anyway. Plus, he'd get killer gas mileage when he wanted it.
skrewdriver88
Nov 3, 2005 06:29 PM
codyb13
Jun 13, 2005 09:51 PM
specv5150
Nov 19, 2003 01:11 PM
NicNitty
Jul 23, 2003 04:33 PM
