P1259-VTEC System Malfunction
it can be a dent in the oil pan not allowing good pressure, the vtec filters could be clogged up or even a problem with the rocker arm assembly which you can check by pulling the valve cover and seeing if any are operating differently than the others
If it happened after the short ram install, did you recheck the VTEC solenoid and wiring harness?
These may have been damaged/disconnected during the install as the VTEC solenoid/wiring harness are next to the Throttle Body.
Oct 23, 2002 08:20 AM
