CLUTCH adjustment question
Old Nov 1, 2005 | 10:35 AM
No2Pencil's Avatar
Default CLUTCH adjustment question
i have a cable ys1 tranny... when the pedle is down on the ground the clutch is ready about to engage. how do i adjust the pedle/clutch distance? pics would help
thanks
i try'd to google it
waiting for reply's cant drive anywhere
Old Nov 1, 2005 | 10:37 AM
31flavorscivic's Avatar
Default Re: CLUTCH adjustment question (No2Pencil)
under hood, locate the clutch cable. Where it connects to the transmission there's an adjustable nut on it. Turn it and find some tension.
Old Nov 1, 2005 | 10:38 AM
CRX Toad's Avatar
You need to go out to where the lever is that is on the tranny that the clutch cable runs into and there should be a plastic adjuster out there. Must times they are "white". Also you can wrap mechanics wire around the rubber so that it makes it more firm.
Old Nov 1, 2005 | 10:50 AM
No2Pencil's Avatar
thanks good shyt
lopezchris21
11
Oct 30, 2008 09:24 PM
BLKHB89
Apr 12, 2008 08:17 AM
stackz
Jan 3, 2007 11:32 AM
spaceman
Sep 24, 2003 12:47 PM
.nate
Sep 12, 2002 12:47 PM
