b16 floods its self
Old Nov 1, 2005 | 09:00 AM
hatchish's Avatar
Default b16 floods its self
ok i have always had this problem with my car even when i had a 8 valve single cam in my hatch some times it wont start only if i let the fuel pump prime, if i turn the key to the half way point when all the lights come on and you can hear the fuel pump work it wont start, but if i just turn the key real fast it starts. people have told me i need to upgrade the fuel pump or its something with the main relay. Has this happened to anyone else?
Old Nov 1, 2005 | 09:09 AM
CALIdelsolSIR's Avatar
Default Re: b16 floods its self (hatchish)
yeah,
happened to me. priming on an old pump ***** everything up. i just replaced the fuel pump, relays, injectors, and fuel rail while i was at it, and now it is perfect.
Old Nov 1, 2005 | 09:56 AM
hatchish's Avatar
which pump did u use
Old Nov 1, 2005 | 10:38 AM
hatchish's Avatar
anyone else
Old Nov 1, 2005 | 10:50 AM
civic_driver's Avatar
i'd start with a fuel pressure regulator (might as well get an adjustable).. if that doesn't fix it, i'd go with a new fuel pump
also, make sure there are no vacuum leaks and that the vacuum is hooked up to the FPR (fuel pressure regulator)
Old Nov 1, 2005 | 02:50 PM
Default Re: (civic_driver)
i used a walboro fuel pump with 310cc RC injectors and a B&M fpr.
pappasmurf
Nov 11, 2024 07:43 AM
Jimster480
17
Oct 27, 2009 06:57 AM
4doorcivic9
Jun 11, 2008 06:31 AM
nicko360
15
Jan 17, 2007 06:22 PM
Mag00n
Dec 20, 2006 12:44 PM
