brake upgrade Q?
Old Nov 1, 2005 | 07:09 AM
slow93si's Avatar
Default brake upgrade Q?
i have a 93 si h/b with 4 wheel disc. and i want to upgrade my brakes, but i dont want to go crazy and spend all that money on a big brake kit. So i guess what i really want to know is besides changeing the pads, fluid, and get ss lines. Is there anything else that i can do that wont kill my pockit?
thanks
Old Nov 1, 2005 | 07:11 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: brake upgrade Q? (slow93si)
Good pads is all you need.
If you have a stock motor, I don't see what purpose there is to upgrade to a "big brake" kit.
Even SS lines are not that necessary IMO. I don't like my SS lines. I only got them because my old ones were f-ed up and the SS was actually cheaper than OEM.
Old Nov 1, 2005 | 07:51 AM
IHateJDM's Avatar
Default Re: brake upgrade Q? (SkoundrelUSA)
you can get a master cylinder brace if you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Good pads is all you need.
pads do make the biggest difference though.
Old Nov 1, 2005 | 07:53 AM
Ricey McRicerton's Avatar
Even SS lines are not that necessary IMO. I don't like my SS lines. I only got them because my old ones were f-ed up and the SS was actually cheaper than OEM.</TD></TR></TABLE>
SS Lines are more for pedal feel than any actual performance aspect.
Good fluid, new blanks, and some good pads will be more than enough.
Old Nov 1, 2005 | 07:59 AM
Unit44justin's Avatar
You can also get cross drilled rotors check out brembo they are good and not very expensive http://www.performancecenter.c...hback/ here is a link to some rotor kits
Old Nov 1, 2005 | 08:00 AM
Default Re: brake upgrade Q? (Unit44justin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit44justin &raquo;</TD></TR><TR><TD CLASS="quote">You can also get cross drilled rotors check out brembo they are good and not very expensive http://www.performancecenter.c...hback/ here is a link to some rotor kits</TD></TR></TABLE>
Bzzzzt. Wrong.
All those are going to do is tear up pads more quickly. Blanks are going to better than non cast "cross drilled" rotors. Rotors that are not cast with the holes in them have a tendency to warp and crack.
Old Nov 1, 2005 | 08:01 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unit44justin &raquo;</TD></TR><TR><TD CLASS="quote">You can also get cross drilled rotors check out brembo they are good and not very expensive </TD></TR></TABLE>
that's all for show these days. back when brake pads created a pocket of air that forced the pad away from the rotor, cross drilled and/or slotted rotors helped. Now that brake pads have evolved, those rotors are no longer necessary.
cute little bastard
Cross-drilled is a no no. Just bling bling factor
Old Nov 1, 2005 | 12:58 PM
slow93si's Avatar
Thanks a lot guys. The main reason y i want to do the brakes is because i am get into auto-x more and more. I also want to do a couple of track days.
Old Nov 1, 2005 | 01:30 PM
Default Re: (slow93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow93si &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot guys. The main reason y i want to do the brakes is because i am get into auto-x more and more. I also want to do a couple of track days.</TD></TR></TABLE>
Definately look into some good DOT4 fluid. That's going to make a huge difference in your fade.
Old Nov 1, 2005 | 01:58 PM
slow93si's Avatar
what brand do u suggest or r they all the same
Old Nov 2, 2005 | 01:17 PM
slow93si's Avatar
Old Nov 2, 2005 | 01:28 PM
Real Ek4's Avatar
this is my brake upgrade (Civic VTi B16A) PowerSlot Brake Rotors (Front) - Goodridge Brake Lines - ATE Super Blue Racing Brake Fluid & Porterfield Carbon Kevlar racing pad R4-S
Old Nov 2, 2005 | 02:22 PM
RTI's Avatar
RTI
If you don't have abs you might also consider changing you MC to one from a 91 ex sedan. The larger piston area will give you a firmer pedal and better brake control for autox and the MC will bolt right up to your booster. However, the pedal will be a little more difficult to press.
Thanks knightsport!
Jun 14, 2005 01:28 PM
jeffk182
Apr 26, 2005 06:36 PM
hybrid88hatch
16
Dec 3, 2003 04:28 AM
youngvedder
Nov 25, 2003 05:36 AM
conesmasher
May 27, 2003 12:26 PM
