is my idle control valve shot
Old Oct 31, 2005 | 08:20 PM
racingant's Avatar
Default is my idle control valve shot
ok i have a b16a swap in my 91 civic si when i go to start the car in the morning it will take a little time to start and when it starts it will idle at 500 rpms for about a min and then go up to 1500 and then when the car warms up it will go back down to 500 rpms and the car will fill like it want to cut off do u think it my idle control valve i have a fuel gauge on the car and it goes up too 44 psi what do u think
Old Nov 1, 2005 | 12:28 AM
92integra_gs's Avatar
have you bled the coolant system? usually thats causes somewhat... and also you got the FITV to blame, TPS sensor, vacuum leak... a lot of stuff to troubleshoot...
Old Nov 1, 2005 | 06:56 AM
racingant's Avatar
Default Re: (92integra_gs)
i not that my bottom coolant hose is has a little hole will that cause that to happen
Old Nov 1, 2005 | 08:14 AM
george34's Avatar
Default Re: (racingant)
When my car warms up the RPM will drop to like 300 or lower(I think sometimes that my car is going to die). I don't know my problem either. do u have to take the radiator cap off and run the car for awhile to make sure the system is bleed fully?
Old Nov 1, 2005 | 08:22 AM
EFz6er's Avatar
Default Re: (george34)
check engine light on?
Old Nov 1, 2005 | 08:25 AM
george34's Avatar
Default Re: (EFz6er)
For me no.
xlusiveracer
40
Jan 23, 2017 09:32 PM
duballstar
Aug 8, 2012 09:54 AM
ser_lyncher
Jul 12, 2007 04:37 PM
acuracy r
Jan 31, 2005 03:20 PM
Carpediem291
Mar 22, 2004 01:44 PM
