engine shaking real bad?
Old Oct 31, 2005 | 05:45 PM
verbose assassin's Avatar
Default engine shaking real bad?
did an auto to manual conversion and im thinking a couple of mount may be loose?
i dont know, but i know that one of the mount is missing, and its the lower passenger side tranny stiffiner.
would re-installing that mount stop the engine from shaking?
or could it be that i've been riding the clutch soo much that something is messed up?
Missing Mount #15 and #12
Modified by verbose assassin at 1:20 PM 11/2/2005
Old Oct 31, 2005 | 08:17 PM
Backk InTheDA's Avatar
I hate everything
Default Re: engine shaking real bad? (verbose assassin)
So your saying your missing a mount completely? If you are, then thats your problem.
Old Nov 1, 2005 | 12:04 AM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbose assassin &raquo;</TD></TR><TR><TD CLASS="quote">
fix that problem first, and if your engine still shakes, come back
Old Nov 1, 2005 | 06:28 AM
lVlemphizStylez's Avatar
Default Re: engine shaking real bad? (Deluzional)
omg dude get that mount ASAP...i drove mine without that mount thinking it would be ok (did auto to manual)...what it did was put uneccesary stress on the rear mount COMPLETELY ripping the rubber in it up....my car went from running a 15.4 to running a 16.6 because of that missing mount and the torn rear one
Old Nov 1, 2005 | 07:47 AM
HONDA RR's Avatar
Fix that mount that is missing and then check to see if the engine still shakes.
Old Nov 1, 2005 | 08:18 AM
SilverDc2's Avatar
Default Re: engine shaking real bad? (HONDA RR)
I drove without that mount for a month or two, felt the same just when you let go off the gas at high speed it jerks a little,
but then again i have hasport mounts
i also did my car auto/manuel, and at the first 10 minutes my car was really unstable, but then i just let it sit for 10 minutes gently giving it gas and it went away...weird..
Old Nov 3, 2005 | 06:03 PM
FFP's Avatar
FFP
You should feel comfortible moving the engine up and down a few inches using the jack, that's completely OK. Just don't pick up the whole front of the car with the jack under the engine.
Make sure you put a wooden block between the oil pan and the jack to prevent damage or denting of the pan. (You don't want to cause a leak)
Running the Car without the mount in the first place = bad idea.
Hope it all works out well.
Old Nov 3, 2005 | 06:19 PM
1dayCivic's Avatar
I'd check all of your other mounts just to see if you didnt tear any of them.
mkazm83
Feb 3, 2006 09:01 PM
flipcivicvtec
Apr 26, 2005 07:59 PM
ILuvJDMITR
May 16, 2004 08:15 AM
balistic CRX
Dec 27, 2001 04:37 AM
