90 accord ignition problems
Old Oct 31, 2005 | 03:33 PM
rev2ninetyper's Avatar
Default 90 accord ignition problems
i just picked up a 90'accord for cheap. the guy said the only thing wrong with the car was the fuel pump. dropped the tank and changed the fuel pump. got fuel now, but no spark. so i changed the cap rotor, wires, plugs, fuel pump, and even replaced every fuse with a new one. still no go. should i just go ahead and fork out the money for a new distributor and coil, or is there something else i should check? i even checked the park shift sensor, but nothing. what do you guys think?
Old Oct 31, 2005 | 03:44 PM
deserthonda's Avatar
Default Re: 90 accord ignition problems (rev2ninetyper)
remove distr cap, put key on, get a test lite chk for power at both coil wires,, you should have power, put test lite at neg side of the coil, have someone crank the engine, if lite pulsates u got a bad coil, if lite does not pulsate u got a bad ignitor ,, u can buy those separately no need to get whole distributor unless a complete reman distr is cheaper .. if u do but a reman distr make sure it comes with ignitor and coil
NWsleeperswaps
Nov 24, 2015 12:31 AM
Will Johnston
May 20, 2012 08:23 PM
exxon
Dec 7, 2011 04:14 PM
Mr. V
Classic Hondas
Jan 8, 2010 07:27 AM
digital_cowboy
Classic Hondas
Jul 10, 2007 02:58 PM
