Brake prob (stop lights)
Old Oct 31, 2005 | 01:50 PM
ice-burg-slimm's Avatar
Default Brake prob (stop lights)
I have 91 ef civic, the fuse for the stop lights and horn keep blowing. The wire that runs to the fuse box under the engine bay, seems to be grounding, but i can't find it. Ontil i can find the prob, i want to know if any one have an idea what the three wires coming from the brake senser is? I want to rig the stop lights so they work.
please help!!
Old Oct 31, 2005 | 02:26 PM
sam385's Avatar
Default Re: Brake prob (ice-burg-slimm)
the white/green wire goes from the fuse block to the brake switch--this wire also goes to the horn switch also. there is a green/white that goes from the brake light switch to the rear lights. -> at least this is how my car is....
Old Oct 31, 2005 | 02:33 PM
primered_ef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">the white/green wire goes from the fuse block to the brake switch--this wire also goes to the horn switch also. there is a green/white that goes from the brake light switch to the rear lights. -&gt; at least this is how my car is....</TD></TR></TABLE>
one reason why the fuse keeps blowing is that theres too much voltage going through the fuse. also check if theres a short-to-ground before the load. thats usually the case with blown fuses
Old Oct 31, 2005 | 03:55 PM
sitrucjr's Avatar
i had the same problem ,, turned out my horn wire was disconnected from the horn and was grounding out on the frame,, the horn is located by the driver front tire
Old Nov 1, 2005 | 04:06 PM
Default Re: Brake prob (glendizzle)
the horn wire is good, so that don't even seem like that's the prob.
do any one knows what the second green/white is .
JDM_rolex
Mar 15, 2025 04:50 PM
mahgnibb
12
Oct 23, 2017 12:29 PM
erikwithak
10
Aug 9, 2009 02:39 PM
Padronis
Jun 29, 2005 08:13 AM
B18C_EJ8
Feb 27, 2004 07:39 AM
