MOTORS
Old Oct 31, 2005 | 11:10 AM
SHIFKU(EF9 HOPE FUL)'s Avatar
Default MOTORS
I JUST BOUGHT AN EF WITHOUT MOTOR WHAT IS THE EASYEST OR LEAST EXPRESIVE MOTOR I CAN DROP IN TO IT OTHER THEN STOCK
( HOW HARD IS ZC DOHC) I KINDA WANNA DROP IN A DOHC MOTOR
THANKS
Old Oct 31, 2005 | 11:13 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: MOTORS (SHIFKU(EF9 HOPE FUL))
first off, TURN OFF THE CAPS.
second, the zc, i think is just as easy as a b16, wiring wise, so the zc dhoc would be the cheapest way to go.
Old Oct 31, 2005 | 11:19 AM
si0385.'s Avatar
the dohc zc is the easiest dohc motor to put in an ef, basicaly just as easy as the sohc and because its non-vtec the wireing is alot easier also,
im prety sure u can use the stock mounts adn wireing harness
Old Oct 31, 2005 | 11:35 AM
RC_Benjamin's Avatar
Default Re: MOTORS (turbodreamz0385)
i donno man they are all pretty EXPRESIVE
Old Oct 31, 2005 | 12:01 PM
Default Re: MOTORS (RS93DA)
MY BAD I MEANT A EG I ALREADY DROPED A ZC IN MY EF
Old Oct 31, 2005 | 12:13 PM
Slow EJ8's Avatar
turn off the caps, maybe then people will take you more seriously instead of being like me and just telling you to turn off caps
and you seem to have your heart set on a ZC from the begining, so i say, go for it
Old Oct 31, 2005 | 12:25 PM
all_conference's Avatar
Does typing in caps get you more replies and help? If so, I'll try to remember this and TYPE MY NEXT THREAD IN ALL CAPS! You sir, are seriously a n00b, even your avatar backs me up on this.
Try using the "Search" function meant for this type of situation. Don't forget to turn off your "Caps Lock" key on your KEYBOARD on your way back to reply about how you can't find the "Search" link.
Back to the topic, the only hard swap is one that you are less knowledgeable of. Your welcome for my time. Enjoy your stay.
Old Oct 31, 2005 | 12:36 PM
ghost_ryder35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHIFKU(EF9 HOPE FUL) &raquo;</TD></TR><TR><TD CLASS="quote">MY BAD I MEANT A EG I ALREADY DROPED A ZC IN MY EF</TD></TR></TABLE>
EG???? wrong forum....... and search please
Old Oct 31, 2005 | 03:13 PM
SETI20's Avatar
STOP SHOUTING!!!!!!
Old Oct 31, 2005 | 04:06 PM
si0385.'s Avatar
Default Re: (SETI20)
the mounts are the same so it woule be just as easy
Old Oct 31, 2005 | 05:28 PM
delsolb16's Avatar
Default Re: (turbodreamz0385)
Who cares if he writes in caps! Dude just wants help! Save your money and get a b18 vtec. Do it right the first time.
Old Oct 31, 2005 | 05:40 PM
Slow EJ8's Avatar
Default Re: (delsolb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolb16 &raquo;</TD></TR><TR><TD CLASS="quote">Who cares if he writes in caps! Dude just wants help! Save your money and get a b18 vtec. Do it right the first time. </TD></TR></TABLE>
BECAUSE ITS HARDER TO READ WHEN SOMETIME TYPES IN ALL CAPS!
(at least for me it is, and i care because im the one reading it to try to see what his problem is to help him)
Modified by Slow EJ8 at 11:46 PM 10/31/2005
Old Oct 31, 2005 | 05:46 PM
The_Todd's Avatar
Farts in the shower
It is called etiquette.
21 pages of swapping goodness: https://honda-tech.com/zerothread?id=878010
Old Nov 1, 2005 | 09:29 AM
Default Re: (.ken)
yo this caps thing is messed up i go online @ work and wheni am working i am supposed to have th caps on for the programs i am supposed to be usin so i accdentil for get to turn of the caps my bad
all_conference if u have somthing up ur @ss dont take it out on me cuz quite frankly i would rather not heard ur B.S
the reason this thread is now in the ef is because i accdently wrote ef when i started it and it was moved my bad
any way so u guyz r sayin a zc should go in to an eg same as it would go in to an ef( what about the obd stuff)
Old Nov 1, 2005 | 09:55 AM
Ace0246's Avatar
Default Re: (SHIFKU(EF9 HOPE FUL))
https://honda-tech.com/zerothread?id=1325319
There's some good info in that link. There has to be a more comprehensive writeup on H-T for this swap, but the term "ZC" won't go through the Search Engine.
http://www.thezcr.com/
This link is to a forum dedicated to the ZC engine. Might find a writeup there as well.
tegracer19
Oct 13, 2007 07:16 PM
jaydmcrx
Mar 6, 2004 10:29 PM
sohcvtec1995
18
Aug 25, 2003 08:09 AM
