b16's pistons in b18c's
Old Mar 8, 2002 | 07:53 AM
Eg6_JDM's Avatar
Default b16's pistons in b18c's
PR3 pistons in a usdm b18c? ......i heard of people using b16's pistons to get higher compression but not sure......does anyone know if it would even fit right?
Old Mar 8, 2002 | 07:56 AM
rainforest's Avatar
Default Re: b16's pistons in b18c's (Eg6_JDM)
yes
Old Mar 8, 2002 | 11:38 AM
Eg6_JDM's Avatar
Default Re: b16's pistons in b18c's (rainforest)
will there be any loss with pr3 pistons in the b18c.......thanks rainforest
Old Mar 8, 2002 | 11:47 AM
sgT's Avatar
sgT
shold only be gains.
compression will go up to mid 11s
Old Mar 8, 2002 | 11:56 AM
Eg6_JDM's Avatar
Default Re: b16's pistons in b18c's (sgT)
is there anything that needs to be replace when installing the pr3 piston
Old Mar 8, 2002 | 12:44 PM
Spade's Avatar
rings.
Old Mar 8, 2002 | 01:17 PM
ahcjar103's Avatar
Default Re: b16's pistons in b18c's (Spade)
rings should be the same for jdm 88-91 pr3's as 94-95 del sol vtec pr3's right?
Old Mar 8, 2002 | 01:20 PM
ahcjar103's Avatar
when you are putting the pistons on the rods, you have to make sure there is at least 1/16" play on each side of the rod. this means taking a little over 1mm off each side of the rod, or taking material out from the piston (i'd do it from the rod). that's the only fitment issue.
Old Mar 8, 2002 | 01:24 PM
sgT's Avatar
sgT
Default Re: b16's pistons in b18c's (ahcjar103)
the pistons only need to be opened up if using a b18c piston on a non b18c rod
Old Mar 8, 2002 | 01:41 PM
VtecDeMoN's Avatar
If I were you I'd look into getting .25 OB pr3 pistons and boring your block out. The reason being is that if your engine has any imperfections or scratches on the cylinder walls a simple hone may not be capable of remeding the situation. Its a good idea but you can do what you wish. Also if you are interested in the CR for your motor with different piston applications hit up Jim's calculator: http://www.bojangs.com/calculator/
Brian
Old Mar 8, 2002 | 06:39 PM
Eg6_JDM's Avatar
Default Re: b16's pistons in b18c's (VtecDeMoN)
thanks for the help!!
ill keep everything in mind
Old Mar 9, 2002 | 09:37 AM
Stunna BEN's Avatar
Don't call it a comeback
Do you think there would be any clearnace problems running PR3 pistons .25 over with a 2 layer headgasket on a full B18c block?
anjgsr
Mar 10, 2010 09:48 AM
mathieucivic
Mar 15, 2009 01:49 PM
alfee
Mar 28, 2004 10:08 PM
JBk24crx
Sep 8, 2003 10:13 PM
BLKCRX
Apr 3, 2002 06:04 PM
