O2 sensor problems!! Need help
Old Oct 31, 2005 | 09:10 AM
DarkBuddha's Avatar
Default O2 sensor problems!! Need help
I have a 92 VX just got a ZC SOHC vtec dropped in and its not reading my O2 Sensor any help would be appreciated im using a p28 ecu
Old Oct 31, 2005 | 09:15 AM
civic_driver's Avatar
is that a 4-wire o2 sensor you got?
Old Oct 31, 2005 | 09:17 AM
2k.civic.si's Avatar
Default Re: (civic_driver)
just disable the o2 in the ecu
Old Oct 31, 2005 | 10:14 AM
DarkBuddha's Avatar
Default Re: (2k.civic.si)
its a 5 wire o2 sensor .... and its eating up gas like nothing right now!!
Old Oct 31, 2005 | 11:25 AM
for the p28 you need a 4-wire o2 sensor... what does each of the wire do for that 5-wire o2 sensor... you might be able to get it to work... the 4-wire has 2 wires for heater, one signal and one ground
Old Oct 31, 2005 | 11:28 AM
hatchi's Avatar
convert your 5 wire o2 to 4 wire.
Old Oct 31, 2005 | 11:34 AM
Relic1's Avatar
Default Re: (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">convert your 5 wire o2 to 4 wire.</TD></TR></TABLE>
exactly
a P28 needs a 4-wire O2.
Old Nov 1, 2005 | 11:44 AM
DarkBuddha's Avatar
Default Re: (Relic1)
does any one know how to convert the 5 wire to a 4 wire?? if so can you help me out?
Old Nov 3, 2005 | 01:41 PM
DarkBuddha's Avatar
Default Re: (DarkBuddha)
is there no one that can help??
Old Nov 3, 2005 | 03:13 PM
Relic1's Avatar
if you have the OEM 4-wire O2...
white wire(O2 signal) connect to the orange/blue wire on the VX O2 plug
green wire(O2 ground) splice into the green/white wire on the IAT or TPS.
black wire(heater control) connect to the yellow/black wire on the VX O2 plug
black wire(heater power) splice into the yellow/black wire on the EACV or injectors
(the drivers shock tower has a bunch of them connected together also)
jDMJeRk
Oct 3, 2019 08:19 PM
BLJ-93eg
Apr 27, 2007 02:03 PM
DEMNTD1
Mar 1, 2006 12:07 PM
7rrivera7
May 22, 2003 01:37 PM
