First job with my new Lincoln 3200 HD
Old Oct 30, 2005 | 10:40 PM
DohcVtecCrx's Avatar
Default First job with my new Lincoln 3200 HD
I started fitting my turbo stuff on and I didn't really like the fitment of the wastegate. I guess it was designed for a d16a6 because on the z6 the wastegate hits the upper radiator hose housing:
Here is what I did, like it says here I hope it clears the hood. When I tighten it down it will go down maybe 1/8 of an inch, so fingers crossed.
I welded the inside and the out. I did the inside for a just in case, because around the outside on the ends I had to worry about the threaded bolts hole and I ran a smaller bead with alot less heat and as you can see from the heat marks it looks like I didn't get as much penetration as I would like. Tomoroows task will be porting the inside of the 2 bolt flange. Looks a little rought in there.
How do you like the welds on the mani? Looks like alot of undercut to me. This, I was told, is an old school revhard race mani. If you think the outside looks bad you should have seen the inside. I have a few hours logged porting this thing. Think it is about time for a ramhorn style manifold.
Old Oct 31, 2005 | 08:26 AM
rhd's Avatar
rhd
keep your mani...serioulsy. the oldschool revhards KICK ***
****, just look at RLZ, howard ran a 10.1@144 on 100octane pump wiht his 1.6L using the same mani (b-series though...)
that thing held the record for a long time...no point in changing it to some overpriced heatsink
Old Oct 31, 2005 | 08:29 AM
rhd's Avatar
rhd
http://www.we-todd-did-racing....x.jpg
Old Oct 31, 2005 | 08:58 PM
Blanket Jackson's Avatar
Default Re: (rhd)
Looks like it is gonna work out! What size is that BTW?
Old Nov 1, 2005 | 09:56 PM
Default Re: (ExcessivePerformance)
38 mm
rhdune16
May 9, 2006 04:15 AM
640K Crew
Feb 24, 2006 05:46 PM
underpressure02
Dec 29, 2003 07:30 AM
Buraku
Nov 5, 2003 11:15 PM
DIY_Racing
Dec 19, 2002 06:14 PM
