HELP! What ECU for a '99 B18B1 ???
Old Oct 30, 2005 | 04:28 PM
sik94hatch's Avatar
Default HELP! What ECU for a '99 B18B1 ???
What ECU should be used in a '93 si hatch. Motor is '99 B18B1, tranny is hydro S80 (i think?) Kid says it has a P05 ECU, is that good?
Old Oct 30, 2005 | 11:35 PM
ek99's Avatar
Default Re: HELP! What ECU for a '99 B18B1 ??? (sik94hatch)
You need a p75 integra ls ecu(94-95) or pr4 integra ls(92-93). po5 is cx and it will run lean.
Old Oct 31, 2005 | 09:38 AM
Katman's Avatar
Default Re: HELP! What ECU for a '99 B18B1 ??? (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 &raquo;</TD></TR><TR><TD CLASS="quote">You need a p75 integra ls ecu(94-95) or pr4 integra ls(92-93). po5 is cx and it will run lean.</TD></TR></TABLE>
An update to this reply...
You can use any 92-95 PR4, P74, and P75 ecu ....which are all LS ecu's.
Or
You can use a P06 (92-95 DX) ecu that's been reprogrammed to LS spec. A P05 is capable of being reprogrammed to LS spec too, but in stock form, it will run lean and only be looking for a single-wire 02 sensor instead of a 4-wire 02 sensor which you should be using for your swap.
Old Oct 31, 2005 | 12:39 PM
HONDA RR's Avatar
crxmex
Dec 27, 2006 09:39 AM
cxhb
Oct 10, 2005 01:39 PM
wm5holla
Sep 23, 2003 01:20 PM
boywonda
Sep 21, 2003 10:05 AM
fiftee_su
Jul 28, 2003 09:55 AM
