OBD2 GSR Swap in 96' EK Hatch
Old Oct 30, 2005 | 02:54 PM
9hatch6's Avatar
Default OBD2 GSR Swap in 96' EK Hatch
i searched. not very good. but i was just wondering exactly what mounts i needed. i got like several responses from ppl. they were all diff. responses so if someone who has done the swap before just let me know which mounts, ect.. i need
Old Oct 30, 2005 | 03:05 PM
9hatch6's Avatar
Default Re: OBD2 GSR Swap in 96' EK Hatch (9hatch6)
anyone?
Old Oct 30, 2005 | 03:07 PM
ek-to-tha-max's Avatar
if you searched im POSITIVE you would find it.
99-00 SI mounts, 99-00 SI shift linkage, obd2a ecu, either p72(gsr) or p73(type r). and you need a vtec obd2a harness. get if from a 96-98 EX harness so ur vtec will work and your stuff like speedo, rpms, fan, etc. will work.
Old Oct 30, 2005 | 03:16 PM
9hatch6's Avatar
Default Re: OBD2 GSR Swap in 96' EK Hatch (ek-to-tha-max)
but the swap comes with a wire harness.
Old Oct 30, 2005 | 06:10 PM
hatchi's Avatar
you will need to reuse your wiring harness. reuse your 2 top mounts. 99-00 si rear bracket, b series front tranny bracket and a/c bracket.
Old Oct 31, 2005 | 10:09 PM
Racersky's Avatar
I'm in the same shoes he's in can someone really help me out?
Old Oct 31, 2005 | 11:12 PM
ReDHaTcHyGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9hatch6 &raquo;</TD></TR><TR><TD CLASS="quote">but the swap comes with a wire harness.</TD></TR></TABLE>
civic and teg harnesses are different u need a civic one .. u can use ur stock mounts but u need the rear bracket from a 99-00 si and the hard block mount on the drivers side from a Si also.. its the cast piece that has the long studs in it ,,, an stuff like front tranny bracket n Ac bracket from a Si... shist linkage from any 92+ b series will work
aaronISthrowed
Dec 20, 2009 08:51 AM
civic337SIR
May 14, 2008 10:56 AM
SIRIUS VTEC
12
Jul 12, 2007 04:45 PM
STRAKTUS
Mar 8, 2006 08:00 PM
SiB16A
11
Sep 27, 2005 07:00 PM
