slowly cranking
Old Oct 30, 2005 | 01:50 PM
NoahSukata's Avatar
Default slowly cranking
sup guys well i just replaced my headgasket.. and got everything tourqd right... and adjusted the valves... well i got to start the car.. and it is slowly cranking over, sounds kinda like the battery is bad/dead.. so i get the jumper cables.. and jump it.. still does it... so i get a good battery out of a running car... still does it... so i think mayb the timing is off... nope tdc and cam gears up... the only thing i did different than everyother headgasket change is adjusted the valves.. could havin the valves too tight/loose cause it to do this? what could be the problem
91 acura integra b18a turbo
Old Oct 30, 2005 | 02:03 PM
2k.civic.si's Avatar
Default Re: slowly cranking (Da-teg)
.007 intake and .008 exhuast i think....does it start? if not you may have the valve adjustment to tight and therefor no compression...my 2 cents
as for turning over slow...could be the starter
Old Oct 30, 2005 | 02:05 PM
rainforest's Avatar
yes the the valves being out if spec will have a no crank condition. but only if they are totally extreamly out of spec. i have had this happen once before they were tooloose and not opening the valves enough to complete the intake/exhaust stroke. most likly something else check spark and for fuel and go from there.
Old Oct 30, 2005 | 02:18 PM
NoahSukata's Avatar
no it wont start.. it turns over too slow to start... sometimes it kinda catches and goes fast for a sec.. then goes back to goin slow...
Old Oct 30, 2005 | 08:59 PM
NoahSukata's Avatar
k guys got it to start.. cleaned out the starter... ok now to keep it ideled i have to turn the distributor all the way toward the car... the gears and everything are lined up at TDC... what could cause it not to idle anywhere else... and it still barely idles... i need to adjust my valves.. cause i hear clacking in the valvecover...
big-cat
Jan 6, 2010 05:59 AM
jglatfelter7
Jul 12, 2009 05:42 PM
Itu
Feb 13, 2008 11:36 AM
zx2gotboost
19
Dec 17, 2005 10:27 AM
