Camshafts wearing/noisy valvetrain
Old Oct 30, 2005 | 10:08 AM
Chuji's Avatar
Default Camshafts wearing/noisy valvetrain
The setup: My valvetrain has always been pretty noisy. Setup is B16 head .5mm oversized ferrera valves, skunk2 valvetrain with over 40k miles. LMA are all working fine. Right now im using stock b16a cams.
The Problem:I went to do a valve adjustment and noticed the cams are wearing on the lobes pretty significantly, valve lash was somewhat tighter than it should be so I adjusted using the larger spec .007" .008" seemed to quiet it a little. (Used .006" .007" before on the looser side, also used the "coathanger" method and tightened my timing belt) Any ideas why my cams are wearing? My only guess is worn valvesprings, or I had the valvelash too tight, what do you guys think? Will my oversized valves or a port/polish increase injector clicking noise , or other valvetrain noise?
Old Oct 30, 2005 | 10:16 AM
sickerhatch's Avatar
Default Re: Camshafts wearing/noisy valvetrain (Chuji)
you should not have to use a coat hanger to tighten your timing belt.if your timing belt is to tight you will wear stuff out very fast.
Old Oct 30, 2005 | 10:25 AM
Chuji's Avatar
Default Re: Camshafts wearing/noisy valvetrain (sickerhatch)
So if the camshafts have wear the rocker arms, rocker shafts, ect are most likely worn as well correct?
Old Oct 31, 2005 | 12:05 PM
Chuji's Avatar
I put on a old tensioner I had and the belt seems pretty loose now, but at least It shouldnt wear anymore. Can anyone tell me if this head is ruined or what?
Old Oct 31, 2005 | 03:11 PM
rainforest's Avatar
possibly oil not getting to the camshafts.
how tight is tight on the valve lash because thats more than likly the problem.
one other thing that i have never seen but have heard of in internet land. is that the valve springs have to high of a spring rate for the stock cam and can damage the lobes.
Old Oct 31, 2005 | 05:04 PM
Chuji's Avatar
Default Re: Camshafts wearing/noisy valvetrain (rainforest)
Im pretty sure im getting oil unless my oil line is clogged. Would you recommend running the motor for like 5 secs with the braided line disconnected to see if oil is getting through?
Old Oct 31, 2005 | 05:08 PM
Chuji's Avatar
Its hard to describe how tight the valve lash was set. When using the .006-.007" feeler gauges some of them were tighter than a "slight drag". When doing a correct valve adjustment you want to just barely feel drag on the feeler gauge correct?
Old Nov 1, 2005 | 10:24 AM
msmotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chuji &raquo;</TD></TR><TR><TD CLASS="quote">Its hard to describe how tight the valve lash was set. When using the .006-.007" feeler gauges some of them were tighter than a "slight drag". When doing a correct valve adjustment you want to just barely feel drag on the feeler gauge correct?</TD></TR></TABLE>
Yes, only a slight drag should be felt. If too tight, the clearance is .001 tighter than you measured.
Old Nov 2, 2005 | 02:05 PM
Chuji's Avatar
Default Re: Camshafts wearing/noisy valvetrain (msmotorsports)
Got the valves adjusted correctly for sure this time, still ticking. The head is definately getting oil. The cam wear is not as bad as I thought and is only on 2-3 lobes not all of them. The ticking is still very loud 1-3k rpms, but at idle its fine. Could this be worn valvesprings?
Rotting Prelude
Jul 26, 2016 01:13 PM
ctownintegra
Oct 27, 2009 09:45 PM
mr_magoo
Aug 23, 2008 12:41 AM
scartail
Apr 12, 2007 04:20 AM
