BAD Speaker wire! HELP!
Old Oct 29, 2005 | 06:45 PM
97LXAcc0rd's Avatar
Default BAD Speaker wire! HELP!
Hi, my passenger side front speaker was removed today and was about to be replaced by my new type-r's. the stock speakers have never worked, and i was wondering how. I found out by putting my new ones in.
It so happens that the ground wire is perfectly fine, but when i put the right front speaker wire onto the new type-r's, they just BUZZ. The sound output from the wire seems to have been disrupted somehow. The wire is a postive RED w/ Green stripes.
What is a possible solution to this dilemma on a bad wire?! THanks all!
Old Oct 29, 2005 | 08:39 PM
97LXAcc0rd's Avatar
Default Re: BAD Speaker wire! HELP! (97LXAcc0rd)
help!
Old Oct 29, 2005 | 09:20 PM
BLKFLSH's Avatar
Try running a whole seperate wire from sterio directly to the speaker to see if you get the buzz with a different wire. If it is definitly the wire that is the problem you have two choices.
1. Run the seperate wire to the door speaker(following the other wires)
2. Try to fix the wire that is there
Number 1. sounds easier to me
Old Oct 30, 2005 | 05:43 AM
H2290's Avatar
Default Re: BAD Speaker wire! HELP! (BLKFLSH)
Agreed. You don't want to try to trace down the OEM wire through all the plugs and sleeves it goes through. You would just be better off running a whole new one.
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
redteg1
Mar 20, 2002 08:47 PM
