my gsr run really slow after i spray it with water
Old Oct 29, 2005 | 05:04 PM
polishprinze's Avatar
Default my gsr run really slow after i spray it with water
hey if u guys can help me out n tell me wuh is wrong wit my motor i would really appriciate it. well this is what happen i was spray engine degreaser into the motor bay. then wash it off with water and started my car, now it run like crap. my vtec doesnt kick and the car is extremely slow. any ideas??
Old Oct 29, 2005 | 05:10 PM
LordAphotic's Avatar
are you missfiring?? which feels like the engine is shaking like crazy.
if so then one or more of the cylinders isnt sparking cause probably water got to one or more of the spark plugs... or you got the actual distributor wet... just dry it all as best as possible... then let it air dry a lil while then start it up.
Old Oct 29, 2005 | 05:12 PM
EGDC2CIVIC's Avatar
Default Re: my gsr run really slow after i spray it with water (polishprinze)
take off the cap and dry it out youll just have to wait untill all the ignition system dries out
Old Oct 29, 2005 | 05:47 PM
t0ekn3e's Avatar
Default Re: my gsr run really slow after i spray it with water (EGDC2CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGDC2CIVIC &raquo;</TD></TR><TR><TD CLASS="quote"> take off the cap and dry it out youll just have to wait untill all the ignition system dries out</TD></TR></TABLE>
same problem my friend had, when he did the same thing to his car
Old Oct 29, 2005 | 06:34 PM
b18a2705's Avatar
1. Always: cover your distributer when you spray your engine compartment with water...
2. Also do you think you sucked up water into the intake /cylinders...
3. Are you flashing any codes
Old Oct 30, 2005 | 10:35 AM
my maint require is on but other than that the motor just shake alot and i have no kind of horsepower what so ever. And everytime i put it in first the motor scream as i press on the gas and shake the whole car
Old Oct 30, 2005 | 10:44 AM
danthemang3's Avatar
Default Re: (polishprinze)
check to see if any water went into your spark plug holes, if it did stuff some paper towels down there and dry it all up.
Old Oct 30, 2005 | 02:25 PM
95tegNONVTEC's Avatar
Default Re: (danthemang3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danthemang3 &raquo;</TD></TR><TR><TD CLASS="quote">check to see if any water went into your spark plug holes, if it did stuff some paper towels down there and dry it all up.</TD></TR></TABLE>
OR...use compressed air to get the majority of the water out and then use a halogen floodlight to get the last drops out cause the heat from the light will dry it out. (remember the compressed air probably has a slight bit of moisture in it unless you have a device to take out the moisture - like for painting) The lights heat will get rid of that.
e30slut
May 30, 2008 08:48 PM
Lude@Heart
Aug 25, 2006 07:24 PM
integradb88
Jul 10, 2006 02:29 PM
katoeh2o
13
Apr 18, 2005 07:04 AM
lakerschamp2000
Oct 1, 2004 04:26 PM
