removing axle from hub.
im having a hard time taking my driver axle off. i tried hitting it with a hammer and it barely moves. i tried wd-40 and hond parts washed and other kind of lubricant and it still dont work. does anybody have any suggestions?
****.. i'm having a major brain fart and cant remember the name, but did u remove the lower cotter pin and nut on the bottom of the hub assembly so you can pull the brake forward?
i assume you are not near a compressor because you could hit it with an air hammer in the recessed part. but you could fit somthing into the recessed part and hit it with a hammer while the knucke was pulled away from the trans
Mr. Giggles
Jan 23, 2007 06:15 PM
