How to change civic SI rear brake pads?
1. Unscrew brake master cylinder cap.
2. Remove lug nuts
3. Remove wheel
4. Using a 10mm socket, remove the two bolts holding the dust shield on.
5. Using a 14mm socket, remove the two bolts holding onto the caliper.
6. Using fingers, remove the brake pads.
7. Using a pry bar like flathead, turn the caliper piston clockwise and push in at the same time to compress the piston.
8. Replace the brake pads.
9. Reverse steps 1-5.
2. Remove lug nuts
3. Remove wheel
Cincinnatux
Oct 4, 2009 10:39 AM
E-brake or Handbrake
54
Oct 11, 2004 03:02 PM
Nocturnal
Jan 4, 2003 05:25 AM
