o2 sensor removal
Old Oct 29, 2005 | 10:50 AM
88crxhfb16's Avatar
Default o2 sensor removal
1988 CRX DX
how do you get to the o2 sensor???
I don't get it. could they make it any harder to get to.
it's lookin like removing the manifold or radiator. is there an easier way???
Old Oct 29, 2005 | 11:19 AM
88crxhfb16's Avatar
bump
Old Oct 29, 2005 | 02:00 PM
crxforum's Avatar
Default Re: (88crxhfb16)
Step 1
Remove the intake arm that goes over the top of the rad.
Step 2
Remove the heat shield with 12mm socket.
Step 3
Whip heat shield over fence into neighbours yard
Step 4
Look down and you will see the O2 sensor there on the side of the header.
Step 5
Get a 7/8ths wrench and get in there and loosen it. Do it carefully because you dont have much room to work with anyways. You dont want to put dents in your rad. If you have a ratchiting wrench from like Mastercraft or SnapOn you can take that and unplug the wire for the sensor and slide it down over the wire and its easier to remove it.
Then put the new one in. Tighten it up. Plug it in the harness. Replace the intake arm over the rad. Look over the fence to see if your heat shield is in a non obvious place and then start it back up.
CRX Forum
Old Oct 29, 2005 | 02:02 PM
crxforum's Avatar
Default Re: (crxforum)
If you have AC you will have to deal with the lines and some other crap. Forgot about that. Just work your way down below them. I removed my AC crap because it was useless to me.
CRX Forum
Old Oct 29, 2005 | 02:12 PM
stickershop.ca's Avatar
Default Re: o2 sensor removal (88crxhfb16)
The easiest way is to use the proper tool for this. An O2 sensor socket. It's basically a really deep socket with a slot in the side for the wire. They aren't cheap though...so borrow one off of a friend if possible.
CustomVW's Avatar
wow on my 89 CRX HF it is way easier...
step 1 open hood and look down
step 2 get o2 sensor tool, rachet and 12" extension
step 3 unplug connector and remove o2 sensor
I just did this today to clean it and put some anti-sieze on the threads...
Old Oct 30, 2005 | 05:59 AM
88crxhfb16's Avatar
Default Re: (CustomVW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CustomVW &raquo;</TD></TR><TR><TD CLASS="quote">wow on my 89 CRX HF it is way easier...
</TD></TR></TABLE>yeah its not the same on an 88 dx.
Old Oct 30, 2005 | 06:00 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">Step 1
Step 3
LOL
Old Oct 30, 2005 | 06:32 AM
crxforum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL </TD></TR></TABLE>
Seriously this is one of those things that Honda made just to **** you off. Some guy is going to be like, "Well it displaces 1/8th of a degree of heat thus decreacing the amount of blah blah blah and adding blah blah blah." There is no use for this part on a Honda it just gets in the way. Whipping it randomly over your shoulder is the only reason for it to exist.
CRX Forum
ajholt7
Jul 31, 2011 06:31 PM
EG-SIXV-TEC
Feb 7, 2009 01:14 PM
cvc323
12
Nov 17, 2004 11:46 AM
Kusai.Nihonjin.Desu
Nov 22, 2003 08:10 AM
neilff
Jun 18, 2003 04:56 AM
