2 Quick Questions
Whatsup?!
I got 2 quick questions:
1] What is the normal tire pressure for a 4D LS?
All my tires read differently and i dont wanna pop one of them so...
2] My Maintenance Required light came on and i just reset it. What would be a reason for it coming on? It blinked 10 times if that helps. I recently had an oil change and i figured that it might be from that if the guy didnt reset. It just went over 188k miles so it could be a mileage thing. Anyone know?\
Thanks a lot
Thanks a lot
1. Check the wall of the tire for the appropriate PSI.
Just like you would check for the tire size.
2. That maint.req. light will come on after a certain number of miles.
Its normal, unless you reset it and it continues to come back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed DC2 »</TD></TR><TR><TD CLASS="quote">1. Check the wall of the tire for the appropriate PSI.
Just like you would check for the tire size.</TD></TR></TABLE>
Don't go by the sidewall, that only tells you the highest pressure the tire is safe at, not the ideal pressure for the car. Check your owners manual, or do what I do and just set them at 35psi and be done with it. You can always adjust the pressure up or down later if you feel the need.
Check the driver's side door jamb for the appropriate tire pressures.
Its normal, unless you reset it and it continues to come back.</TD></TR></TABLE>
on the money... i think the light comes on every 3k.
Thanks a lot
I reset the MR warning and havent heard from it since so i guess im ok on that. The tires I put on 35 because I dont have the manual but it seems ok because before they were all different...one front tire was at 45 and the other at 25 and now they are worn off in a weird way.
Should be all set
Thanks again!
Should be all set
Thanks again!
djafactor
May 30, 2002 01:20 PM
