Intalling grs strut bar on EG?
Old Mar 7, 2002 | 09:16 PM
mantic6t9's Avatar
Default Intalling grs strut bar on EG?
Ok i'm getting a gsr front strut bar an need some advice on how to mount it. My car all ready has the holes for it. I know i need bolts washers and nuts. My main questions is this, How should i mount it. Should i thread the bolt from the underside of the fender well and put the nut on the top or thread the bolt through the top and put the nut in the fenderwell. Has anyone done this?
[Modified by mantic6t9, 6:16 AM 3/8/2002]
Old Mar 7, 2002 | 09:44 PM
B_CRUZ!'s Avatar
Default Re: Intalling grs strut bar on EG? (mantic6t9)
i have done it. the guy i bought it off of hooked me up with the bolts. it doesn't matter which way you tread the screws. he said the bolts were from random honda parts.
Old Mar 8, 2002 | 12:25 AM
mantic6t9's Avatar
Default Re: Intalling grs strut bar on EG? (B_zurC)
Anyone else got an idea of what the best way is?
Old Mar 8, 2002 | 12:47 AM
ahcjar103's Avatar
just go to home depot and get some bolts and nuts. not hard. costs maybe a dollar. just make sure you get grade 8 bolts/nuts.
Old Mar 8, 2002 | 04:46 AM
BakedCookies's Avatar
just put the thred to the top, thats how the factory does it... other than that its REALLY doesnt matter...
Old Mar 8, 2002 | 06:08 AM
Canttx's Avatar
Dont put the bolt going into the fender well, this will make it harder for you to remove the bar in the future. Do it like factory and when you need to remove the bar ie, swapping, engine work...etc. you can just remove the 4 nuts.
Old Mar 8, 2002 | 08:04 AM
mantic6t9's Avatar
Default Re: Intalling grs strut bar on EG? (Canttx)
so put the bolt through the top and the nut and washers under the fenderwell?
Old Mar 8, 2002 | 08:40 AM
deviant94ex's Avatar
New User
nope....put the bolt up form the bottom and put the nuts on top. i used a wrench to hold the bolt on the bottom while i tightened the nut on top with a socket. use a little loctite and you wont have any problems whatsoever. this worked great for me and was a cheap mod (free bar from Scary1109 and $0.52 in nuts and bolts from home depot). good luck.
CHRIS
Old Mar 8, 2002 | 08:45 AM
mantic6t9's Avatar
Default Re: Intalling grs strut bar on EG? (deviant94ex)
ok thanks, that's what i was going to do. I was confused 'cause no one really said clearly what to do.
Old Mar 8, 2002 | 09:55 AM
Charles B.'s Avatar
Yes, yes put some nuts on top; that is what i am going to do.
Old Mar 8, 2002 | 10:02 AM
mantic6t9's Avatar
Default Re: Intalling grs strut bar on EG? (SuperDuperEG)
Ok so i should get grade 8 bolts but what size and how long? Do i put washers on both sides or just under the bolt head?
[Modified by mantic6t9, 7:02 PM 3/8/2002]
Old Mar 8, 2002 | 11:31 AM
Doctor CorteZ's Avatar
1" long is plenty , get stainless ones , and put the threads pointing up
Old Mar 8, 2002 | 09:39 PM
mantic6t9's Avatar
Default Re: Intalling grs strut bar on EG? (Doctor CorteZ)
ttt
redturbo0
Sep 25, 2013 09:18 AM
JDM_WHR
Jan 13, 2010 05:09 PM
9deuce
May 29, 2003 09:34 PM
Maverick77
Jan 20, 2003 08:46 PM
satintegra
Jun 12, 2002 07:44 AM
