GREEN air filters? Any good?
So I've got an air filter made by "GREEN". What do you think/Have you heard about this company? Are their filters good or no good? Should I make a short ram air intake using this filter or just leave stock air box?
Thanks in advance
PS (I've searched)
Thanks in advance
PS (I've searched)
I too am attempting to chose the best quality and best fit replacement air filter for my Honda ('97 Civic EX coupe) that has an (apexi style eBay copy) cold air intake.
Did you find out any more info on GREEN air filters? Everyone tells me to go with K&N but they are very pricey and I am curious of the alternatives; there
must be alternatives.
Regarding replacing your air box with a cold-air intake, I highly recommend it. Relatively little cost outlay (especially if you shop eBay), extreemly easy for my installation anyway. I understand some earlier models require you cut a hole for the new intake pipe- it depends on what model and year you own. If your current air box has a tube going straight down to another plastic box, through a metal flange that is the hole you need for a full cold air intake. Otherwise you have to cut a hole or go with what they call a short-ram which in my opinion defeats the whole purpose of an new air intake system and that is most importantly intaking air from outside the engine compartment. In our case from underneath it.
Good luck and let me know what filter you decide to buy.
thanx
must be alternatives. Regarding replacing your air box with a cold-air intake, I highly recommend it. Relatively little cost outlay (especially if you shop eBay), extreemly easy for my installation anyway. I understand some earlier models require you cut a hole for the new intake pipe- it depends on what model and year you own. If your current air box has a tube going straight down to another plastic box, through a metal flange that is the hole you need for a full cold air intake. Otherwise you have to cut a hole or go with what they call a short-ram which in my opinion defeats the whole purpose of an new air intake system and that is most importantly intaking air from outside the engine compartment. In our case from underneath it.
thanx
piggydog
Oct 13, 2005 01:30 PM
