Swap finished BUT wheels spinning when not in gear
havent started a car on jackstands in awhile, it's the second swap I did guess I forgot...I was frigin pissed thought I did something wrong with the clutch install, anyways thanks and
me
me
Yea even tho the trans is in neutral the gears on both shafts are still spinning even tho there not engages, so by having next to no resistance now from the axles they spin the shaft slightly causing the wheels to spin. Nothing to worry about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">i didnt know the wheels would spin in neutral when the car is off the ground
learn something every day</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">Its the viscosity of the tranny fluid.The drag of the oil "engages" the shafts in the tranny.
Glenn</TD></TR></TABLE>
There are also friction washers that act as brakes for countershaft first and second gears. The drag from these washers also contribute to this phenomenon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">did you get into the car while it was on jackstands o.O isnt that kinda dangerous?</TD></TR></TABLE>
Dangerous?? The car isnt gonna go nowhere unless you didnt sit the jack stands in a secure place on the frame
i just leanred something new
Funny the day i started my car up after my swap it was on jack stands and i thought the same thing..... lol
soon to find out that it was normal...
glad you found somthign out new
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 »</TD></TR><TR><TD CLASS="quote">Funny the day i started my car up after my swap it was on jack stands and i thought the same thing..... lol
glad you found somthign out new</TD></TR></TABLE>
you guys are weird, have you guys ever change tires? thats why you dont loosen them up while they are off the ground or vice versa
Well i was only so worried about somthing going wrong with the swap job that little things that i knew about already made me think twice like is is soppsoe to do that why is this like that.. ya know what i mean....
lol a similar thing happened to me the first time I started up my swap. Then I remember how the gears are in a manual tranny. The gears are all bunched up on 2 shafts and obviously the friction between them is enough to make the wheels spin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI »</TD></TR><TR><TD CLASS="quote">
i just leanred something new</TD></TR></TABLE>
