Problem with rear caliper
Anyone ever have thier rear caliper sorta freeze up and lightly rub against the rotor causing a squeaking/squealing noise on a G3 gsr integra? Does anyone know how to fix this or do i need to repalce the entire caliper? Thanks so muc
h for help/info.
h for help/info.
I had a rear caliper that would freeze up on occasion. Check the dust boots, slide pins, and inside the caliper bracket where the pins go. This caliper was only wearing out the inner pad because it was not moving freely back and forth. If it is hitting both pads, replace/rebuild your caliper.
