Problem with rear caliper
Old Oct 29, 2005 | 05:20 AM
b18c198's Avatar
Default Problem with rear caliper
Anyone ever have thier rear caliper sorta freeze up and lightly rub against the rotor causing a squeaking/squealing noise on a G3 gsr integra? Does anyone know how to fix this or do i need to repalce the entire caliper? Thanks so muc h for help/info.
Old Oct 29, 2005 | 05:55 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Problem with rear caliper (b18c198)
Calipers can be rebuilt for little money. Go to google and search "hondahookup manual". You'll find the information that you need.
Old Oct 30, 2005 | 01:16 PM
b18c198's Avatar
Default Re: Problem with rear caliper (Dogginator)
Thanks found that info real helpful!
Old Oct 30, 2005 | 04:11 PM
dmiller33's Avatar
I had a rear caliper that would freeze up on occasion. Check the dust boots, slide pins, and inside the caliper bracket where the pins go. This caliper was only wearing out the inner pad because it was not moving freely back and forth. If it is hitting both pads, replace/rebuild your caliper.
Old Oct 30, 2005 | 06:47 PM
Sam92Teg's Avatar
Any chance it is just your pad wear indicator rubbing on your rotor, you might just need new pads.
Skidoorcng
Honda Civic (2006 - 2015)
Jun 1, 2015 09:14 AM
vanny_david
Suspension & Brakes
Feb 22, 2010 05:52 AM
mynameisChris
Aug 15, 2009 06:57 AM
vtecmissle
Nov 15, 2004 03:46 PM
